![]() | Home > Maintenance & Modifications > Quick compressor fix question |
Dannutt Member Since: 06 Jan 2014 Location: Bucks Posts: 60 ![]() ![]() ![]() |
Stupid really but when I take the compressor off for the refurb does the car have to be in access mode to stop it dropping down suddenly when I disconnect the hoses or car I have it raised up in full 4x4 mode? I'm guessing access.
Huh yeah first time I tried to jack it up to change the brake wear cable that wheel just rose into the sky for about 5 minutes
IF you can get the bolts off, then def recommend the full kit. You will be able to change the piston seal and carbon ring without too much difficulty. Problem is with the exhaust spring and rubber plunger, the bolt can become corroded to the case.
Are the odds pretty good everything will come apart?
Ah hold on, that's a different kit. It fixes the popular crack in the air dryer unit (LR have stopped supplying the dryer on its own for £70 and have superseded the part with the new compressor at £500!!!)
In fact, your best off taking this repair service. |
No can do Im afraid. It means leaving Mrs Dan and the baby without a car for several days. I need to plan around doing it over the weekend.
Presumably Mrs Dan wouldn't be able to use the car whilst the pump was away? |
Not really. Bodsys Brake Bible
For a few quid you could hire a Fiesta or other small motor to keep the family mobile then you'd buy yourself time to do what's best ! |
I hear ya but that rebuild is £150+26p&p so now your getting on for half the price of a new replacement.....
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 169 ![]() |
hi
