Home > Technical > Propellor noise from the front |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Wheel bearing or front diff |
Sun Aug 17 2014 10:01am |
hunter Member Since: 22 Sep 2013 Location: Nottingham Posts: 318 |
Fingers crossed thats its a wheel bearing................. Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more |
Sun Aug 17 2014 11:44am |
Topgeartowers Member Since: 18 Mar 2014 Location: London Posts: 48 |
Thanks, from what I read online those both sound likely.
Sun Aug 17 2014 1:28pm |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
just changed front offside wheel hub myself (had to change hub and bearing as they're one unit) simple job. had most of the tools except for the torque wrench but this cost me only 30 quid. SO about £90 quid in total plus a few hours. I was lucky enough to pick up a new genuine hub off eBay for £60, from a private seller Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Sun Aug 17 2014 2:35pm |
Allow around £100 for a decent quality wheel bearing. Unless you get lucky, as above
Sun Aug 17 2014 8:48pm |
Wheel bearing as some here suggested - booked into MD this weekend.
Fri Aug 22 2014 9:21am |
Are you sure it ain't the air-conditioning/fan kicking in?
Fri Aug 22 2014 10:36am |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
Fromt diff is about £450ish recon at IAWA. Is the noise on the over run or just on steady acceleration? |
Mon Jan 05 2015 10:03pm |
Can you confirm, is the problem road speed related or engine speed related? If road speed, then I agree with the above posts, if engine speed, then I would suspect Alternator, Water pump etc. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Tue Jan 06 2015 9:29am |
