Home > Technical > Propellor noise from the front
Topgeartowers
My 06 RRS 2.7 has developed a strange noise, and after reading countless posts about what it might be, I thought it might be worth actually posting my noises and seeing if anyone could help.
It's a propellor like noise which speeds up as the car speeds up. It's a grumbling noise that pulses, both on acceleration and also when lifting off, it definitely sounds like it's coming from the front of the car. It also seems like you can feel it every so slightly through the steering wheel. There is steering wheel shudder at 50mph (but I figured that's because it needs an alignment).
Stuck my head out the passenger window at low speed and thought I could hear some random rattles from under the car.
Car has 61k on the clock, all done by me and FLRSH ( don't know if that helps).
Can anyone help?
Post #433475 Sun Aug 17 2014 10:34am
Disco_Mikey
Wheel bearing or front diff
Post #433476 Sun Aug 17 2014 11:01am
hunter
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Fingers crossed thats its a wheel bearing................. Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more
Post #433490 Sun Aug 17 2014 12:44pm
Topgeartowers
Thanks, from what I read online those both sound likely.
In people's experience; what are the broad cost for wheel bearing replacement and front diff? (What do I need to brace for basically!)
Thanks for the help so far
Post #433498 Sun Aug 17 2014 2:28pm
tanloverluke
just changed front offside wheel hub myself (had to change hub and bearing as they're one unit) simple job. had most of the tools except for the torque wrench but this cost me only 30 quid. SO about £90 quid in total plus a few hours. I was lucky enough to pick up a new genuine hub off eBay for £60, from a private seller Thumbs Up Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #433506 Sun Aug 17 2014 3:35pm
Disco_Mikey
Allow around £100 for a decent quality wheel bearing. Unless you get lucky, as above Thumbs Up
Around an hours labour to replace
Front diff is a whole lot more. Up into nearly 4 figures at that point
Post #433543 Sun Aug 17 2014 9:48pm
Topgeartowers
Wheel bearing as some here suggested - booked into MD this weekend.
Thanks for all advice lads
Post #433930 Fri Aug 22 2014 10:21am
drdelrrs
Are you sure it ain't the air-conditioning/fan kicking in?
Turn off aircon and see if noise is changed
Post #433934 Fri Aug 22 2014 11:36am
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Fromt diff is about £450ish recon at IAWA. Is the noise on the over run or just on steady acceleration?
Post #447515 Mon Jan 05 2015 11:03pm
SRE
Spain
Can you confirm, is the problem road speed related or engine speed related? If road speed, then I agree with the above posts, if engine speed, then I would suspect Alternator, Water pump etc. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #447530 Tue Jan 06 2015 10:29am
