Home > Technical > Amber suspension light
chi
Hi . I have a 2005 RR sport 55 plate 75,000 miles.
I am getting a amber suspension warning light on the dash with a message saying "" suspension Fault. Normal ride Height only " The access height button is also disabled. If i switch ignition off and re start the problem clears but has today happened several times. 4 X 4 screen all okay and no sensors lights flashing red.
Any ideas ?
Many thanks
Keith
CHI
Post #427539 Wed Jun 18 2014 1:59pm
Lancer6
I sometimes have the same issue, after some research some people tend to suggest the battery starting to go?
Post #427553 Wed Jun 18 2014 4:40pm
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I have the same - its intermittent when it comes on, can be after 1 minutes, 5 minutes, 20 minutes!
I had read about the battery causing error lights to come up - my suspension doesn't change in feel or height. I read also that is the battery is not an OEM Land Rover one, this can usually happen.
Whats a good price and recommendation on battery?
Post #427574 Wed Jun 18 2014 6:31pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
These messages also appear when the compressor itself is getting worn out. 60,000 miles seems to be the average for the life expectancy of the compressor.
Post #427577 Wed Jun 18 2014 7:10pm
chrisebabes
This may sound odd but I had the same about 6 months ago, was told to try this... turn car on and off 3 times and hey prestoe no amber light and its not been on since. Thumbs Up TDV8 2007 window tints, side steps.
Post #427579 Wed Jun 18 2014 7:14pm
micalee
Ill try this tomorrow. Report to follow
Post #427581 Wed Jun 18 2014 7:16pm
chi
Thanks for all the replies. Compressor changed at approx 40,000 so hopefully not that , also recent battery change , but not a landrover oem. Embarassed
Will try the turning on and off three times and report back.
Keith
CHI
Post #427639 Thu Jun 19 2014 9:32am
Stuart
I had the same and the garage diagnosed a compressor. It is being fitted next week, but they seem certain.
Post #427656 Thu Jun 19 2014 3:48pm
tailormadefun
United Kingdom 2006 Range Rover Sport Supercharged Zermatt Silver
I had this fault, and it's cause was water in the connector to the rear lights on the drivers side, the rubber had come away so water could get in, I replaced the rubber and made it water tight and that has cleared the fault, apparently if the braking system senses any fault it will do this, including a blown brake light bulb
Post #427713 Fri Jun 20 2014 6:36am
micalee
So, turned engine on and off three times, but to no avail! Its got warranty, so not overly concerned.
Post #427751 Fri Jun 20 2014 1:22pm
Chin
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Stornoway Grey
Ha good luck with that (see my post in general section)
Post #427801 Fri Jun 20 2014 9:05pm
Stuart
Said compressor is fitted and fault cured.
Post #428389 Wed Jun 25 2014 7:43pm
micalee
Mine is in Monday for diagnosis
Post #428434 Thu Jun 26 2014 9:07am
Fish
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
Amber light
I had the same light on my sport shortly after taking delivery, it would clear on engine start up but then come on again after 30 minutes or so. I had the 4 wheel alignment done (it need it due to tyre wear) which didn't clear it, i changed out the brake pedal switch, which didn't clear it. I then renewed the discs and pads all round as i knew they were worn, i found the front wear sensor contacts were worn/broken, after changing them out i have had no more amber light. Thumbs Up 2.7 HSE, Audi A6 Exec, Honda Accord Exec, Volvo 440, Volvo 360
Post #428442 Thu Jun 26 2014 10:31am
micalee
Its bizarre how seemingly unrelated issues cause a suspension fault light!
Post #428449 Thu Jun 26 2014 11:01am
