![]() | Home > Technical > Amber suspension light |
Lancer6 Member Since: 17 Jan 2014 Location: Widnes Posts: 14 ![]() ![]() ![]() |
I sometimes have the same issue, after some research some people tend to suggest the battery starting to go? |
micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241 ![]() ![]() ![]() |
I have the same - its intermittent when it comes on, can be after 1 minutes, 5 minutes, 20 minutes!
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
These messages also appear when the compressor itself is getting worn out. 60,000 miles seems to be the average for the life expectancy of the compressor. |
chrisebabes Member Since: 14 Jul 2010 Location: Cornwall Posts: 79 ![]() ![]() ![]() |
This may sound odd but I had the same about 6 months ago, was told to try this... turn car on and off 3 times and hey prestoe no amber light and its not been on since. |
Ill try this tomorrow. Report to follow |
chi Member Since: 15 May 2010 Location: hampshire Posts: 49 ![]() ![]() |
Thanks for all the replies. Compressor changed at approx 40,000 so hopefully not that , also recent battery change , but not a landrover oem. |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
I had the same and the garage diagnosed a compressor. It is being fitted next week, but they seem certain. |
tailormadefun Member Since: 06 Apr 2014 Location: Kent Posts: 51 ![]() ![]() ![]() |
I had this fault, and it's cause was water in the connector to the rear lights on the drivers side, the rubber had come away so water could get in, I replaced the rubber and made it water tight and that has cleared the fault, apparently if the braking system senses any fault it will do this, including a blown brake light bulb |
So, turned engine on and off three times, but to no avail! Its got warranty, so not overly concerned. |
Chin Member Since: 02 Sep 2013 Location: London, UK Posts: 66 ![]() ![]() ![]() |
Ha good luck with that (see my post in general section) |
Said compressor is fitted and fault cured. |
Mine is in Monday for diagnosis |
Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60 ![]() ![]() ![]() |
I had the same light on my sport shortly after taking delivery, it would clear on engine start up but then come on again after 30 minutes or so. I had the 4 wheel alignment done (it need it due to tyre wear) which didn't clear it, i changed out the brake pedal switch, which didn't clear it. I then renewed the discs and pads all round as i knew they were worn, i found the front wear sensor contacts were worn/broken, after changing them out i have had no more amber light. |
Its bizarre how seemingly unrelated issues cause a suspension fault light! |
