Home > Technical > hdc problem |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
Not sure about the wheel but the HDC and special programmes sounds like your batteries gone |
Fri Feb 21 2014 8:31am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
Check your brake lights - a blown bulb can cause HDC errors.
Fri Feb 21 2014 9:49am |
blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66 |
checked all these today, battery & charging been tested, bulbs, all good, front pads, and wear sensors abs sensors, brake warning light comes on first, n/s front wheel still locking on and off, caliper all ok and free,
Fri Feb 21 2014 7:37pm |
Have you tried driving with the DSC turned off? If so, does it still produce the symptoms? Could be a faulty yaw sensor or steering wheel angle sensor causing the DSC to think you're sliding and so using the brakes to try to keep you on the correct course. 2012 SDV6 - it's missing a couple of cylinders
Sat Feb 22 2014 9:26am |
a yaw sensor, whats that ? never heard of them before went for a diagnostics check today, and come up with about 5 codes, main one steering sensor, did a battery & charge check again, charging ok but battery slightly dowm, that's not what halfords said yesterday but the good news is that it's probably due to the battery, the system shuts parts down to save power, and causes phantom error codes, so i'll go and get a new battery, but make sure it the right one he said, or it i'll be the same, so i left it to them to get, going back monday for it to be fitted, and the codes cleared, ho and apparently it has to be told it's got a new one fitted |
Sat Feb 22 2014 5:15pm |
The yaw sensor sits on the floor under the centre console and is used by the DSC to determine yaw rate (unsurprisingly).
Sat Feb 22 2014 6:08pm |
well that's what i thought it would measure, but still none the wiser to what the yew is to be measured ?
Sat Feb 22 2014 6:22pm |
As the vehicle turns a corner, it experiences yaw - that is a rotational moment about the centre of its wheelbase. There is a maximum amount of yaw that can be attained whilst all four tyres are gripping. If the yaw exceeds that figure then the rear tyres have lost grip and a spin is about to occur. By comparing the yaw and the steering angle it's possible for the DSC system to determine whether the front or rear has lost grip (for example, reducing yaw with no reduction in steering angle would indicate the front tyres have lost grip and understeer is occurring).
Sun Feb 23 2014 8:09am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Could be as simple as the steering angle sensor needing calibrated, but needs plugged in to check the live data |
Sun Feb 23 2014 8:24am |
collected rrs today with new battery, and all fault codes cleared, 100 yards down the road, n/s front wheel locks on, and dash lights back on, back to garage, and they check codes, only one comes up now, steering angle
Tue Feb 25 2014 8:05pm |
another new battery today 900 amps, steering angle recalibrated, codes cleared again, test drive and the dash lights back on, this time code comes up for turbos, garage checking for split turbo pipes, |
Thu Feb 27 2014 8:05pm |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
Well, the other day I found out that HDC is only working when you drive forward.
Fri Feb 28 2014 12:37pm |
HDC does work in reverse. HDC is overridden by the brake pedal - if you touch the brakes then the system puts you back in control. 2012 SDV6 - it's missing a couple of cylinders
Fri Feb 28 2014 12:47pm |
HDC does indeed work on reverse.
Sun Mar 02 2014 9:21am |
