Home > Technical > hdc problem
blueiceplus
United Kingdom 2008 Range Rover Sport TDV6 SE Cairns Blue
hdc problem
hi to every one, just join the site, and wonder if anybody can help please, got my first rrs a month ago Very Happy , 2008 2.7 se with 110,000 miles,
as it was well due for a cambelt change, i carry this out, (front & rear new pulleys oil pump) as well as a few other jobs, went out on a test drive Very Happy after about 4 miles n/s/f wheel did some strange things locking on and off, (like abs) Crying or Very sad hdc lights came on, as wall as brake light under temp gadge, saying special programs not available,
switch off and restarting sorts it out for about a mile, an then it's back on, any ideas please
Post #414907 Fri Feb 21 2014 4:47am
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Not sure about the wheel but the HDC and special programmes sounds like your batteries gone
Post #414921 Fri Feb 21 2014 9:31am
Check your brake lights - a blown bulb can cause HDC errors.
Check your battery. Check that the alternator is charging it properly. 2012 SDV6 - it's missing a couple of cylinders
Post #414932 Fri Feb 21 2014 10:49am
blueiceplus
checked all these today, battery & charging been tested, bulbs, all good, front pads, and wear sensors abs sensors, brake warning light comes on first, n/s front wheel still locking on and off, caliper all ok and free,
so must be down to breaking system.
Post #414986 Fri Feb 21 2014 8:37pm
Have you tried driving with the DSC turned off? If so, does it still produce the symptoms? Could be a faulty yaw sensor or steering wheel angle sensor causing the DSC to think you're sliding and so using the brakes to try to keep you on the correct course. 2012 SDV6 - it's missing a couple of cylinders
Post #415045 Sat Feb 22 2014 10:26am
blueiceplus
a yaw sensor, Mad whats that ? never heard of them before Sad went for a diagnostics check today, and come up with about 5 codes, main one steering sensor, did a battery & charge check again, charging ok Very Happy but battery slightly dowm, that's not what halfords said yesterday Evil or Very Mad but the good news is that it's probably due to the battery, the system shuts parts down to save power, and causes phantom error codes, so i'll go and get a new battery, but make sure it the right one he said, or it i'll be the same, so i left it to them to get, going back monday for it to be fitted, and the codes cleared, ho and apparently it has to be told it's got a new one fitted Laughing
Post #415083 Sat Feb 22 2014 6:15pm
The yaw sensor sits on the floor under the centre console and is used by the DSC to determine yaw rate (unsurprisingly).
Not surprised to hear it's the battery. It's a very common cause of this type of fault (hence why it was mentioned earlier in the thread). 2012 SDV6 - it's missing a couple of cylinders
Post #415093 Sat Feb 22 2014 7:08pm
blueiceplus
well that's what i thought it would measure, but still none the wiser to what the yew is to be measured ?
thanks for help anyway
Post #415099 Sat Feb 22 2014 7:22pm
As the vehicle turns a corner, it experiences yaw - that is a rotational moment about the centre of its wheelbase. There is a maximum amount of yaw that can be attained whilst all four tyres are gripping. If the yaw exceeds that figure then the rear tyres have lost grip and a spin is about to occur. By comparing the yaw and the steering angle it's possible for the DSC system to determine whether the front or rear has lost grip (for example, reducing yaw with no reduction in steering angle would indicate the front tyres have lost grip and understeer is occurring).
Once the DSC knows whether the vehicle is understeering or oversteering then it can activate the appropriate brake to generate a counter-yaw moment to reduce the problem. If a sideways movement occurs when the steering is straight ahead then it will register that and reduce the power - that's one reason why you need to turn off DSC when off road; it will kill the power at the moment you probably want to be able to apply more power. 2012 SDV6 - it's missing a couple of cylinders
Post #415157 Sun Feb 23 2014 9:09am
Disco_Mikey
Could be as simple as the steering angle sensor needing calibrated, but needs plugged in to check the live data
Post #415161 Sun Feb 23 2014 9:24am
blueiceplus
collected rrs today Very Happy with new battery, and all fault codes cleared, 100 yards down the road, n/s front wheel locks on, and dash lights back on, Evil or Very Mad back to garage, and they check codes, only one comes up now, steering angle
sensor, said it needs calibrating, off to a 4x4 center to tomorrow who say they can do it, just seen disco mikey said it could be this, thanks, but tonight i see the battery which should be the right one is only 800 a and not 950 as the original is, could one confirm what it should be for a 2.7 diesel.
Post #415507 Tue Feb 25 2014 9:05pm
blueiceplus
another new battery today 900 amps, steering angle recalibrated, codes cleared again, test drive and the dash lights back on, this time code comes up for turbos, garage checking for split turbo pipes,
Post #415860 Thu Feb 27 2014 9:05pm
jochem00
Well, the other day I found out that HDC is only working when you drive forward.
I was offroading on a path with snow and ice and came to a stand still, the only way to go was to reverse. HDC in reverse would have come in very handy and as the car was just sliding down the hill and out of control unless I took the foot of the brakepedal.
anyway, I made it without scratches.
Post #415935 Fri Feb 28 2014 1:37pm
HDC does work in reverse. HDC is overridden by the brake pedal - if you touch the brakes then the system puts you back in control. 2012 SDV6 - it's missing a couple of cylinders
Post #415940 Fri Feb 28 2014 1:47pm
jochem00
HDC does indeed work on reverse.
yesterday I got stuck again in the snow on a steep path up. pushed the yellow button, but the car in Reverse and off the brake pedal. indeed the HDC was working correctly and saved me from an uncontrolled slide down the hill as that was what would have happened without the system.
Post #416110 Sun Mar 02 2014 10:21am
