![]() | Home > Technical > Tdv6 Engine fitted wont start |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
can you please tell me what you mean by gen tool to fit signal ring,the mechanic helping me said he just knocked it on ![]() Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !! Gone rr sport supercharged. Loved but 11mpg !!! current,triumph stag mk2...current bmw 325 sport convertible |
its getting worse the scanner will not communicate with the engine management now and we have tried 3 different scanners,it will only communicate with body control and we are getting codes b1b02 low frequency coil and b1c57 passive start ignition relay and they will not clear |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 ![]() |
Check what voltage your getting at each injector just with the ignition on, then let us know, as to me it sounds like you have a main ecu problem, have you checked for water damage at the 3 main sockets and pins..?.
thanks for reply,i havnt checked ecu sockets,it was running fine before we took the engine out and its been dry stored ever since ,is there anything else that can blow the ecu silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
no sign of water ingress at the 3 sockets silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Does anyone know. As you have gathered my sport won't start,since refitting repaired engine we have not refitted front end is headlights slam panel bumper suspension etc etc question is could all of this being off cause it not to start : |
Have you disconnected the airbag sensors on the front end ? If so, are they still disconnected ? |
I'm not sure. Possibly would that prevent it starting silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
No, it will still start with the whole front end stripped.
Ahh OK mike thanks. I got excited then... |
Post a picture of your cam pulleys, as fitted to the engine |
Will do tommorow thanks for your help |
Ah sorry, i was only thinking of possible suggestions as a pal of mine was refitting a front end on his VW Golf and it wouldn't even turn over till all sensors reconnected and radiator refitted etc etc. He had to have all sensors and ecu's reset by the dealer in order to start the car. It had front end damage and airbags had gone off though. |
That would be expected, as an accident would throw the car into "crash mode"
