Home > Technical > Tdv6 Engine fitted wont start
Page 1 of 4 1234>
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
Error code Error code p1621 turns ober but wont start. Any ideas Big Cry silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #413693 Wed Feb 12 2014 6:00pm
gazzc
Sorry meant to be in technical silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #413694 Wed Feb 12 2014 6:06pm
Here's a starting point Smile
http://www.rrsport.co.uk/forum/post324036.html
P1621 Serial Data Link Dead Fault ON THE WAY: BMW F21 M140i
Post #413697 Wed Feb 12 2014 6:14pm
flack
Its a problem with your Immobilizer code words do not match hows the battery's on the key Fobs
Flack Thumbs Up
Post #413720 Wed Feb 12 2014 8:17pm
gazzc
As far as i know the batteries are ok. It was fine before we took out engine and rebuilt it mind u it has been off the road for 6 weeks silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #413730 Wed Feb 12 2014 9:08pm
Moved it for you. Thumbs Up
Sorry i can't help with your none starting problem.
Post #413738 Wed Feb 12 2014 10:04pm
gazzc
Cheers Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #413750 Wed Feb 12 2014 10:40pm
flack
I just wonder if you need to do the lift pump sequence, did you change any software during the rebuild..or injectors..
Flack Thumbs Up
Post #413766 Wed Feb 12 2014 11:11pm
gazzc
Hi lift pump sequence ??? Changed nothing. silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #413769 Wed Feb 12 2014 11:28pm
aljo
flack means it may need the lift pump resetting with fault mate or similar diagnostics equipment Thumbs Up
Post #413770 Wed Feb 12 2014 11:43pm
gazzc
Oh right. Cheers i will get on to it tomorrow with a clear head Rolling Eyes silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #413772 Wed Feb 12 2014 11:49pm
gazzc
quick update,immobilser fault code has gone now as using other key,but new code is saying cam sensor air gap???the car started fine before we took engine out so cant understand why cam sensor would just fail or has it Confused silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #414062 Fri Feb 14 2014 7:45pm
flack
Who set the timing up and what method did you use...your code is suggesting that the ecu does not know the position of the camshafts..
Flack Thumbs Up
Post #414075 Fri Feb 14 2014 9:23pm
gazzc
My friend who is a mechanic with a garage/mot station timed it up. With a tool he fabricated. Maybe we should purchase the proper locking pin kit. As its looking like timing out isn't it Bow down silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #414079 Fri Feb 14 2014 10:04pm
gazzc
Error codes po341 and b1c57?? silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #414101 Sat Feb 15 2014 10:21am
Page 1 of 4 1234>
