Home > Technical > Tdv6 Engine fitted wont start |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 |
can you please tell me what you mean by gen tool to fit signal ring,the mechanic helping me said he just knocked it on silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !! Gone rr sport supercharged. Loved but 11mpg !!! current,triumph stag mk2...current bmw 325 sport convertible |
Tue Mar 04 2014 2:45pm |
its getting worse the scanner will not communicate with the engine management now and we have tried 3 different scanners,it will only communicate with body control and we are getting codes b1b02 low frequency coil and b1c57 passive start ignition relay and they will not clear silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Wed Mar 05 2014 10:02am |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Check what voltage your getting at each injector just with the ignition on, then let us know, as to me it sounds like you have a main ecu problem, have you checked for water damage at the 3 main sockets and pins..?.
Wed Mar 05 2014 2:52pm |
thanks for reply,i havnt checked ecu sockets,it was running fine before we took the engine out and its been dry stored ever since ,is there anything else that can blow the ecu silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Wed Mar 05 2014 4:55pm |
no sign of water ingress at the 3 sockets silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Thu Mar 06 2014 10:30am |
Does anyone know. As you have gathered my sport won't start,since refitting repaired engine we have not refitted front end is headlights slam panel bumper suspension etc etc question is could all of this being off cause it not to start : silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Thu Mar 13 2014 7:55pm |
Have you disconnected the airbag sensors on the front end ? If so, are they still disconnected ? |
Thu Mar 13 2014 8:05pm |
I'm not sure. Possibly would that prevent it starting silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Thu Mar 13 2014 8:42pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4408 |
No, it will still start with the whole front end stripped.
Thu Mar 13 2014 8:54pm |
Ahh OK mike thanks. I got excited then... silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Thu Mar 13 2014 8:58pm |
Post a picture of your cam pulleys, as fitted to the engine |
Thu Mar 13 2014 8:59pm |
Will do tommorow thanks for your help silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Thu Mar 13 2014 9:05pm |
Ah sorry, i was only thinking of possible suggestions as a pal of mine was refitting a front end on his VW Golf and it wouldn't even turn over till all sensors reconnected and radiator refitted etc etc. He had to have all sensors and ecu's reset by the dealer in order to start the car. It had front end damage and airbags had gone off though. |
Thu Mar 13 2014 9:07pm |
That would be expected, as an accident would throw the car into "crash mode"
Thu Mar 13 2014 9:13pm |
