![]() | Home > Technical > Tdv6 Engine fitted wont start |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
Come on fellas any ideas we are stumped. Oh bought timing tool and its spot on |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 ![]() |
If it starts to fire when you give a squirt of brake cleaner then it must be lack of fuel, have you had the filter off?, does fuel flow from the bleed screw at the top of the engine. Can you here the fuel pump running in the tank. See if you can get a diagnostic kit on it and crank it over to see if the fuel rail pressure is ok..
thanks for reply,yes we have fuel at the injectors,cam sensor is coming up again now,we took it off the other day and cleaned it and the fault code cleared but we ran a scan this morning and its come back so i will order one and try that |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
I have never seen a cam sensor fail, in 9 years. The only time I have ever seen a cam sensor fault, is when the timing has been wrong.
yes mike that was my thoughts aswell but im really scratching my head now |
If the fault is still there with 2 different cam sensors, then its likely the cam sensors are OK.
Don't you think it could be a fuel problem mike with it firing when I give it a sniff silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
No. Easy start will make any engine run for a few seconds, thats why its called easy start. The fact that it stops running tells you that its either not squirting fuel in, or its squirting at the wrong time. Doesn't mean its a fuelling issue |
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
I did a quick read trough your posts
Are the cam pulleys on the right sides? They are different |
hi yes we fitted a crank/conrod,we have checked timing twice and it seems to be spot on but we are just taking off covers to check again as we cant get to the bottom of it ,thanks |
yes mike we marked the pulleys before removing silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Did you have gen tool to fit signal ring?
The 2 pulleys are physically different though, and only 1 has the trigger on the back of the sprocket. I meant have the sprockets been fitted to the correct sides? |
