![]() | Home > Maintenance & Modifications > Cam belt change |
J.blase Member Since: 01 Jan 2014 Location: Essex Posts: 24 ![]() ![]() ![]() |
Thank you do Thay need changing if so when thanks john. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9023 ![]() ![]() ![]() |
Chains don't require replacement |
medders Member Since: 03 Feb 2014 Location: portsmouth Posts: 148 ![]() ![]() ![]() |
After the panicking my mechanic thinks the belt,has been changed at some point ! Not too fussed as I would rather be safe then sorry, he didn't do the fuel pump belt due to timing and a tool so it's booked I'n with a diesel specialist |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
Thats some mark up |
The diesel pump will be timed ...... |
No its not |
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
^^^^ Medders - Disco_Mickey's right;
Either didn't want to, or couldn't do the back belt, so made up an excuse |
He's a honest and reputable mechanic and trust him for sure, will look more into it but main thing I can drive knowing the cam belt been done thank god |
