Home > Maintenance & Modifications > Cam belt change
Page 3 of 3 <123
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Chains 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #414009 Fri Feb 14 2014 2:33pm
J.blase
United Kingdom 2007 Range Rover Sport 4.4 V8 HSE Bonatti Grey
Thank you do Thay need changing if so when thanks john.
Post #414010 Fri Feb 14 2014 2:43pm
Chains don't require replacement Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #414017 Fri Feb 14 2014 3:24pm
medders
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
After the panicking my mechanic thinks the belt,has been changed at some point ! Not too fussed as I would rather be safe then sorry, he didn't do the fuel pump belt due to timing and a tool so it's booked I'n with a diesel specialist Smile main thing the cam is done £330 including auxiliary belt. Thumbs Up
Post #414222 Sat Feb 15 2014 9:41pm
Disco_Mikey
Thats some mark up Shocked
FWIW, the rear belt is not timed, nor does it need any special tools...
Post #414229 Sat Feb 15 2014 10:09pm
medders
The diesel pump will be timed ......
Post #414240 Sat Feb 15 2014 10:25pm
Disco_Mikey
No its not Thumbs Up
Post #414261 Sun Feb 16 2014 4:23am
drdelrrs
^^^^ Medders - Disco_Mickey's right;
Modern electronic diesel systems only need a high-pressure pump not an "injection pump" - it makes me a little nervous that your mechanic doesn't know this and how to replace its belt.
While doing the dismantling not changing all the belts at the same time doesn't seem prudent and in my opinion is a missed opportunity.
Post #414277 Sun Feb 16 2014 10:21am
Disco_Mikey
Either didn't want to, or couldn't do the back belt, so made up an excuse Whistle
Post #414279 Sun Feb 16 2014 11:14am
medders
He's a honest and reputable mechanic and trust him for sure, will look more into it but main thing I can drive knowing the cam belt been done thank god
Post #414282 Sun Feb 16 2014 11:32am
Page 3 of 3 <123
