![]() | Home > Faults & Fixes > RANGE ROVER SPORT TAPPING NOISE!!!!! |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
link doesn't work |
jonesy_boys Member Since: 18 Oct 2013 Location: cardiff Posts: 45 ![]() ![]() ![]() |
Hi, it should do? cheers. |
Mouse middle button. Sounds like tappet?? |
cheers buddy. Has anyone ever changed them? is it hard to do? |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
i am very sure your car has spun a big end ,i have just had one rebuilt and it sounded identical ,dont drive or run it or you knacker the crank completely,sorry to be the bearer of bad news,garry |
AWW, BLOODY HELL. :/, ANY IDEA HOW MUCH IT COST BUDDY? CHEERS. |
its just cost me 2700 to build my own engine ,that was with the labour in and out,massive job mate,luckily i bought this sport knowing the fault and got it cheep,cranks going on these cars is quite a common problem,make sure you have the crank hardened /nitrided or it wont last 5 mins |
AW NEVER. :/. HOW DO I FIND OUT IF IT DEFO IS THAT? THERES NO FAULT COMING UP SEE. |
mine sounded identical mate,and everyone was saying tappets blah blah blah the noise from the knackered rod will be penetrating up the engine to make you think its at the top,the big end shells spin on these engines BLOCK THE OIL WAY causing major damage,you wont get any fault codes |
Infactt mate just drop.the engine oil and siv it. Keeping your fingers toes and everything else crossed and if there is no metal bits floating around I could be wrong.keep us informed pal silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Ok buddy, thanks very much for your help. il have a look in the morning now and let you know. fingers crossed as i don't have that sort of money as the moment. |
Good luck |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
And i second that |
Cheers guys |
