![]() | Home > Maintenance & Modifications > What life expectancy for Anti Roll bushes on a 2010 RRS |
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
Unfortunately it is |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Mine were recently done at 43k miles. You did well. |
norlan Member Since: 21 Jun 2011 Location: Moray Firth Posts: 45 ![]() ![]() ![]() |
Mine went at 19,000 miles on current motor and 35,000 on last one. |
stornoway10 Member Since: 03 Feb 2013 Location: Southport Posts: 60 ![]() ![]() ![]() |
Gents
[/quote]Thanks for the replies---i don't suppose Land Rover are going to replace them under warranty are they ?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
I had the front ARB bushes replaced under the extended warranty so a vehicle in original warranty should be covered I would think.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Is this an expensive job out of warranty? L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
It is a DIY job if you have the tools/ability so it shouldn't be expensive anywhere really. I think a LR dealer charges about £250 fitted so an indie easily should be able to get it below £200. The bushes aren't expensive - it's mostly labour. 2012 SDV6 - it's missing a couple of cylinders
Bomber H Member Since: 17 Apr 2012 Location: Abingdon / Reading Posts: 200 ![]() |
What are the tell tale signs of failure?
Lancer6 Member Since: 17 Jan 2014 Location: Widnes Posts: 14 ![]() ![]() ![]() |
I too have that wonder of " I wonder if mine are knackered" even though i have an idea its always good to get an answer that matches your thoughts....Anyone??? |
TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139 ![]() ![]() ![]() |
You will hear them knocking if they are worn. Any pothole, speedbump or even a moderately uneven surface will prompt the noise. I could sort of feel the knock under my feet too. |
RainHard Member Since: 07 Sep 2013 Location: Lonehill Posts: 20 ![]() ![]() ![]() |
I got 15000km out of the last set - Front, back are fine (6mths)! Dealer replaced under parts warranty. No knocking but bad sqeaking - very embarrasing! My concern is that the vehicles with the ARC are not easy to DIY. |
