Home > Maintenance & Modifications > What life expectancy for Anti Roll bushes on a 2010 RRS |
adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110 |
Unfortunately it is
Sun Dec 08 2013 6:10pm |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
Mine were recently done at 43k miles. You did well. |
Sun Dec 08 2013 6:18pm |
norlan Member Since: 21 Jun 2011 Location: Moray Firth Posts: 45 |
Mine went at 19,000 miles on current motor and 35,000 on last one. |
Sun Dec 08 2013 8:41pm |
stornoway10 Member Since: 03 Feb 2013 Location: Southport Posts: 60 |
Gents
Sun Dec 08 2013 9:42pm |
[/quote]Thanks for the replies---i don't suppose Land Rover are going to replace them under warranty are they ?
Sun Dec 08 2013 10:04pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8991 |
I had the front ARB bushes replaced under the extended warranty so a vehicle in original warranty should be covered I would think.
Sun Dec 08 2013 11:32pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
Is this an expensive job out of warranty? L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Mon Dec 09 2013 2:07am |
It is a DIY job if you have the tools/ability so it shouldn't be expensive anywhere really. I think a LR dealer charges about £250 fitted so an indie easily should be able to get it below £200. The bushes aren't expensive - it's mostly labour. 2012 SDV6 - it's missing a couple of cylinders
Mon Dec 09 2013 7:09am |
Bomber H Member Since: 17 Apr 2012 Location: Abingdon / Reading Posts: 200 |
What are the tell tale signs of failure?
Thu Dec 12 2013 1:53pm |
Lancer6 Member Since: 17 Jan 2014 Location: Widnes Posts: 14 |
I too have that wonder of " I wonder if mine are knackered" even though i have an idea its always good to get an answer that matches your thoughts....Anyone??? |
Tue Jan 21 2014 3:29pm |
TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139 |
You will hear them knocking if they are worn. Any pothole, speedbump or even a moderately uneven surface will prompt the noise. I could sort of feel the knock under my feet too. |
Tue Jan 21 2014 5:37pm |
RainHard Member Since: 07 Sep 2013 Location: Lonehill Posts: 20 |
I got 15000km out of the last set - Front, back are fine (6mths)! Dealer replaced under parts warranty. No knocking but bad sqeaking - very embarrasing! My concern is that the vehicles with the ARC are not easy to DIY. |
Fri Jan 24 2014 6:35am |
