Home > Maintenance & Modifications > What life expectancy for Anti Roll bushes on a 2010 RRS
stornoway10
United Kingdom 2013 Range Rover Sport SDV6 HSE Orkney Grey
Chaps
The question is as per the subject line, mine has just gone past 50k and has gone all clunky and squeeky, is that normal?
Thanks
Reecy
Post #405341 Sun Dec 08 2013 6:54pm
adigorn
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Unfortunately it is Thumbs Up
On some cars wont even last that long
Post #405343 Sun Dec 08 2013 7:10pm
Stuart
Mine were recently done at 43k miles. You did well. Rolling with laughter
Post #405346 Sun Dec 08 2013 7:18pm
norlan
Scotland 2008 Range Rover Sport TDV8 HST Stornoway Grey
Mine went at 19,000 miles on current motor and 35,000 on last one.
Post #405365 Sun Dec 08 2013 9:41pm
stornoway10
ARBs
Gents
Thanks for the replies---i don't suppose Land Rover are going to replace them under warranty are they ?
If not, would you fit the polyeurathane ones to replace the originals??
Thanks
Reecy
Post #405371 Sun Dec 08 2013 10:42pm
adigorn
[/quote]Thanks for the replies---i don't suppose Land Rover are going to replace them under warranty are they ?
Quote:
on 10my motor - warranty should do
have you ACE (aka DR) - i bet you have
if yes use upgraded clamps + genuine bushes
Post #405379 Sun Dec 08 2013 11:04pm
I had the front ARB bushes replaced under the extended warranty so a vehicle in original warranty should be covered I would think.
As for poly bushes, I think there have been comments on here from people who tried it and went back to the LR bushes because the poly ones ruined the ride. 2012 SDV6 - it's missing a couple of cylinders
Post #405390 Mon Dec 09 2013 12:32am
ilard
Is this an expensive job out of warranty? L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #405394 Mon Dec 09 2013 3:07am
It is a DIY job if you have the tools/ability so it shouldn't be expensive anywhere really. I think a LR dealer charges about £250 fitted so an indie easily should be able to get it below £200. The bushes aren't expensive - it's mostly labour. 2012 SDV6 - it's missing a couple of cylinders
Post #405398 Mon Dec 09 2013 8:09am
Bomber H
What are the tell tale signs of failure?
Visible failure if I poke around underneath (and am able to identify them)?
I've heard from previous owners / friends that they are a regular replacement item due to wear, so now drive every where thinking 'I wonder if mine are knackered?'!!! 2016 VW Golf GTD DSG
2007 Exige S British GT SE
Gone : 2011 3.0TDV6 HSE, Stornoway Grey, Ivory, Piano Black Trim, Paddleshift, Privacy Glass, Side Steps, Mud Flaps, Heated Steering Wheel, Timed Climate & Remote Park Heating Smile
Post #405882 Thu Dec 12 2013 2:53pm
Lancer6
I too have that wonder of " I wonder if mine are knackered" even though i have an idea its always good to get an answer that matches your thoughts....Anyone??? Question
Post #410483 Tue Jan 21 2014 4:29pm
TDV8Mat
England 2013 Range Rover Sport Supercharged HSE Santorini Black
You will hear them knocking if they are worn. Any pothole, speedbump or even a moderately uneven surface will prompt the noise. I could sort of feel the knock under my feet too.
Post #410502 Tue Jan 21 2014 6:37pm
RainHard
South Africa 2009 Range Rover Sport Supercharged Alaska White
I got 15000km out of the last set - Front, back are fine (6mths)! Dealer replaced under parts warranty. No knocking but bad sqeaking - very embarrasing! My concern is that the vehicles with the ARC are not easy to DIY.
Post #410887 Fri Jan 24 2014 7:35am
