Home > In Car Electronics > Adding Freeview/Rear View Cam Required |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
is it only when it's on satnav screen Peachy, what about when you're in the main screen ? i'm hardly ever in satnav screen and dont want to have to switch to it just to have to get the reverse camera working. call me lazy !
Fri Nov 29 2013 6:01pm |
The gvif unit plugs into the satnav DVD player and interrupts the signal to the screen, therefore, it needs to be on the satnav screen. The warning message screen is ok, it doesn't need to have the map on specifically. Bodsys Brake Bible
Fri Nov 29 2013 6:26pm |
bodsy, why then is awd man getting the reverse camera coming on regardless of what screen he's on ? it's due either to 1) it being wired incorrectly, or 2) he's dillusional Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Fri Nov 29 2013 6:39pm |
Errrrr without offending, I'd have to pick number 2... Bodsys Brake Bible
Fri Nov 29 2013 6:41pm |
just pm'd him...let's get this put to bed once and for all.
Fri Nov 29 2013 6:46pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
TLL - Harry has the same set up as me - helped by Bodsy I believe it sounds worse than it is - what do you use your other 2 screens for ? Settings & 4x4 mode ??? Do you live in a field & need to change the settings on your music every 2 mis - I will video it tomoz & send it to your e-mail 16MY Estoril Blue SVR.............
Fri Nov 29 2013 6:49pm |
Peachy, i live in dorset which is one big muddy field ! the problem i suppose is when im faced with a restriction, in this case having to be on satnav screen, my brain goes all funny and negative. i want things to be easy and smooth (just like my hoes ).
Fri Nov 29 2013 7:17pm |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 |
TLL sorry about the late reply been away for a while.
Thu Jan 09 2014 7:44pm |
Thanks for that Harry.
Thu Jan 09 2014 8:45pm |
TLL the topic details everything that was installed.
Fri Jan 10 2014 8:38am |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
Not if you are on info 4x4 screen '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Fri Jan 10 2014 11:57am |
