Home > Technical > Big Fuelling Issue
Page 1 of 5 12345>
jdgeary1
2006 Range Rover Sport TDV6 HSE Sumatra Black
Big Fuelling Issue
My Car is suffering from dropping into limp mode randomly when accelerating hard
Its in the garage at the moment and they are struggling to find the fault having already spent money to get the high pressure pump and in tank pump changed
Fuel lines have been checked ecu check injectors and various other things so far
Its still throwing up a fuel deviation fault code
Has anyone ever had this issue as so far my bill must be in excess of £3000
Any help appreciated as its a real mystery fault and at the moment range rover technical are getting involved to try and locate it
Its been in the garage a week already so I really need my car back
Post #386545 Fri Jun 21 2013 10:59am
flack
Have they changed the fuel filter there's been a few dodgy ones about..
Flack Thumbs Up
Post #386553 Fri Jun 21 2013 12:07pm
JPR 1
Mine did exactly the same a couple of months ago, ended up being the fuel filter, it still took them nearly a week though to find it. I would say this is definatley what is wrong with yours.
Hope you get it sorted. Thumbs Up Current Volvo XC90 R Design T8
Gone 2010 TDV8. Stornoway Grey
Gone VW R50, AUDI S8, ML320 Sport, FFRR V8
Stolen 2007 TDV8.
Post #386561 Fri Jun 21 2013 1:26pm
jdgeary1
Yep fuel filter changed twice so far
Post #386593 Fri Jun 21 2013 7:50pm
jdgeary1
Had the wiring out and checked it all as well
Range Rover have said that this fault is a total nightmare GREAT
Post #386594 Fri Jun 21 2013 7:56pm
flack
Have they checked the turbo actuator linkage to make sure that is free and not seizing up..
Flack Thumbs Up
Post #386595 Fri Jun 21 2013 8:02pm
SpikePCR
South Africa 2006 Range Rover Sport Supercharged Santorini Black
Check the pressure sensor on the fuel rail mine did the same turned out to be a faulty sensor
Post #386596 Fri Jun 21 2013 8:02pm
jdgeary1
Ahhh thanks will suggest those two as well and have them checked
Post #386624 Sat Jun 22 2013 8:34am
alanp69
Ireland
Hi .... I'd be very interested in the outcome of this as my 07 TDV6 is doing much the same (see recent post in Technical issues titled Faults at Speed) so far they've done injectors and filter but still not sorted, my biggest worry is that when the injectors were done they didn't do the filter so they could be dirty again !
Let me know how you fair
Post #387265 Fri Jun 28 2013 12:19pm
jdgeary1
Sounds like a very similar issue, I have had both fuel pumps replaced so far, fuel filter, injectors checked and they are fine, ecu checked, electricals checked and still no fault found.
I have the range rover electrician down today to hook up there own laptop and software to my car and to test drive it to create the fault and analyse the data.
Its driving me crazy at the moment, as well as having a huge bill to come for basically nothing at the moment.
I think this will unfortunately be my first and last RRS.
Post #387266 Fri Jun 28 2013 12:26pm
alanp69
Ireland
I feel your pain ££££££££ , Mine has been in 3 times with this now and were none the wiser ! ... Add to that for the NCT (MOT in Ireland) I had to buy 2 tyres , then it failed on a suspension imbalance so I had to buy 2 rear suspension units which set me back €1000 fitted and now this fuel fault .... If that's what it is ? Like yourself my patience and wallet are getting thin !
Post #387278 Fri Jun 28 2013 1:58pm
jdgeary1
Ok a further update if anyone has any clues, it seems after further tests and diags by a top range rover electronics guru, the fuel issue seems to be happening only when the car is under load.
The car is fine on a ramp running but when driving under normal conditions the fuel pressure seems to drop.
Anyone any ideas?
Post #387645 Wed Jul 03 2013 10:05am
flack
Have they checked the vent is clear for the fuel tank so it can breath and not cause a vacuum while your under load.
Flack Thumbs Up
Post #387649 Wed Jul 03 2013 11:08am
jdgeary1
Ah, could be, will see if that has been checked also and let you know the results.
Post #387652 Wed Jul 03 2013 11:31am
CUCO
Spain
easy:
open the tank cap and test it
Post #387668 Wed Jul 03 2013 2:59pm
Page 1 of 5 12345>
