Home > In Car Electronics > SAT NAV |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Check the Sat Nav unit to see if the gps cable has been dislodged from the unit by somebody's feet .
Tue May 21 2013 5:19pm |
That's the GPS unit unable to get a signal Mike
Tue May 21 2013 7:53pm |
MIKEB Member Since: 21 May 2013 Location: Norfolk Posts: 6 |
Thanks have had a look at unit and all wires are connected Can anyone tell me where the GPS ariel can be located so I can check that end is OK |
Wed May 22 2013 8:38am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1843 |
Does your Sat Nav have the option to look at the satellites that are being used and signal strength?
Wed May 22 2013 8:43am |
Unfortunately this option is not available on my unit Lost GPS signal in UK whilst on long trip it just started telling me I was in the North Sea after having worked fine |
Wed May 22 2013 8:48am |
Mike,
Wed May 22 2013 12:42pm |
Many Thanks have had a read and it sounds promising Next step get a new antenna fin and give it a go Thanks Again MIKEB |
Wed May 22 2013 3:10pm |
Get into the secret menu and you will be able to see what the GPS is seeing. Mike
Wed May 22 2013 4:52pm |
Thanks how do I do that please |
Wed May 22 2013 5:22pm |
MikeB, I think MSE is referring to the diagnostics menu accessed using the '753' code. If you search for '753' (without the quote marks) you'll find the instructions to get into it. One of the options shows you the altitude and longitude and latitude plus all sorts of other gobblydegook. Presumably if the antenna ain't working then this information may not be showing? 2008 MY Java Black TDV8 HSE |
Mon May 27 2013 6:50pm |
