Home > In Car Electronics > SAT NAV
MIKEB
England 2006 Range Rover Sport TDV6 HSE Rimini Red
SAT NAV
Sat Nav
GPS icon has red line through it and sat nav does not now where it is
Thanks to all who replied to my problem I tried a aftermarket antenna and it worked no red line through GPS and all working OK now. I guess I will have to get a new Shark fin antenna. If anyone has one to sell or knows where I can locate one please let me know
Post #383671 Tue May 21 2013 11:50am
flack
Check the Sat Nav unit to see if the gps cable has been dislodged from the unit by somebody's feet .
Flack Thumbs Up
Post #383699 Tue May 21 2013 5:19pm
mse
That's the GPS unit unable to get a signal Mike
2014 Facelift Discovery
Post #383713 Tue May 21 2013 7:53pm
MIKEB
Re: SAT NAV
MIKEB wrote:
Sat Nav
Thanks have had a look at unit and all wires are connected
Can anyone tell me where the GPS ariel can be located so I can check that end is OK
Post #383740 Wed May 22 2013 8:38am
jimbg
Does your Sat Nav have the option to look at the satellites that are being used and signal strength?
If so, it will give a clue. If satellites are just weak then the GPS is probably working but a poor connection to the receiver.
You have not moved the car a long distance powered off have you? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #383743 Wed May 22 2013 8:43am
MIKEB
Unfortunately this option is not available on my unit
Lost GPS signal in UK whilst on long trip it just started telling me I was in the North Sea after having worked fine
Post #383745 Wed May 22 2013 8:48am
Paddi
Mike,
Pretty sure this thread will help you:
http://www.rrsport.co.uk/forum/topic17893....gps+aerial
Always worth a search Smile 2008 MY Java Black TDV8 HSE
Post #383779 Wed May 22 2013 12:42pm
MIKEB
Paddi wrote:
Mike,
Many Thanks have had a read and it sounds promising
Next step get a new antenna fin and give it a go
Thanks Again
MIKEB
Post #383802 Wed May 22 2013 3:10pm
mse
Get into the secret menu and you will be able to see what the GPS is seeing. Mike
Post #383821 Wed May 22 2013 4:52pm
MIKEB
Thanks how do I do that please
Post #383824 Wed May 22 2013 5:22pm
Paddi
MikeB, I think MSE is referring to the diagnostics menu accessed using the '753' code. If you search for '753' (without the quote marks) you'll find the instructions to get into it. One of the options shows you the altitude and longitude and latitude plus all sorts of other gobblydegook. Presumably if the antenna ain't working then this information may not be showing? 2008 MY Java Black TDV8 HSE
Post #384136 Mon May 27 2013 6:50pm
