![]() | Home > Faults & Fixes > Help Suspension light on !! |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 ![]() ![]() |
Yellow or red?
jakeob Member Since: 21 Nov 2012 Location: cheshire Posts: 64 ![]() ![]() ![]() |
Sorry i should have said,,, Its Yellow
Does the air suspension compressor sound noisy it's situated on the passenger side rear - just in front of the rear wheel. They are known to fail - I had the same symptoms as yourself for about 3 months until it finally went altogether ? 16MY Estoril Blue SVR.............
No theres no noise at all,,, Out of interest how many miles did you do before it went all together?? |
Not many - I only do about 6k a year in the RRS. It was an intermittent fault then 1 day it just stayed on yellow - I reset the fault but it remained yellow. We disconnected the compressor then reconnected to see if it changed anything but the car just bottomed out - the only solution was to replace the compressor. I could tell that the one that was removed had already been refurbed. It's been fine since. Others might be able to put you in the right direction but if its noisy its probably on its way out.
Zippy Member Since: 16 Jun 2012 Location: London Posts: 16 ![]() ![]() |
The same thing happened to me today too. Got home turned the car off came back out and the light did not not come back on same again there is no noise from the compressor ? |
My back end has now dropped to the stopps,,,, just drove the last 600 miles to my destination in france...
it definatley sounds like a new compressor is needed.
That could be an option, i will try to contact him,,,
Found a very helpfull and freindly LR dealer in Valance who fitted a new compressor+relay Cost 730 euro car now running fine.
yes, it's the 'fart' releases a little pressure then it gets ready to self level. |
