Home > Faults & Fixes > Help Suspension light on !! |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 |
Yellow or red?
Sat Jan 26 2013 4:32pm |
jakeob Member Since: 21 Nov 2012 Location: cheshire Posts: 64 |
Sorry i should have said,,, Its Yellow
Sat Jan 26 2013 4:47pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 |
Does the air suspension compressor sound noisy it's situated on the passenger side rear - just in front of the rear wheel. They are known to fail - I had the same symptoms as yourself for about 3 months until it finally went altogether ? 16MY Estoril Blue SVR.............
Sat Jan 26 2013 5:22pm |
No theres no noise at all,,, Out of interest how many miles did you do before it went all together?? |
Sat Jan 26 2013 6:52pm |
Not many - I only do about 6k a year in the RRS. It was an intermittent fault then 1 day it just stayed on yellow - I reset the fault but it remained yellow. We disconnected the compressor then reconnected to see if it changed anything but the car just bottomed out - the only solution was to replace the compressor. I could tell that the one that was removed had already been refurbed. It's been fine since. Others might be able to put you in the right direction but if its noisy its probably on its way out.
Sat Jan 26 2013 7:30pm |
Zippy Member Since: 16 Jun 2012 Location: London Posts: 16 |
The same thing happened to me today too. Got home turned the car off came back out and the light did not not come back on same again there is no noise from the compressor ? |
Sun Jan 27 2013 5:53pm |
My back end has now dropped to the stopps,,,, just drove the last 600 miles to my destination in france...
Mon Jan 28 2013 5:58pm |
it definatley sounds like a new compressor is needed.
Mon Jan 28 2013 6:07pm |
That could be an option, i will try to contact him,,,
Mon Jan 28 2013 7:29pm |
Found a very helpfull and freindly LR dealer in Valance who fitted a new compressor+relay Cost 730 euro car now running fine.
Fri Feb 01 2013 9:46am |
yes, it's the 'fart' releases a little pressure then it gets ready to self level. perfectly normal.
Fri Feb 01 2013 11:00am |
