Home > Faults & Fixes > Help Suspension light on !!
jakeob
England 2007 Range Rover Sport TDV8 HST Java Black
Just packing the RRS for a trip to France and the Bl***dy Suspesion warning light is on Big Cry Big Cry
Tried turning it off and on ect but it stays on
It doesnt drop down to the stops anytime and is stuck in normal driving height,,,
Dont know if it will be ok to drive 2k ?????
Post #371039 Sat Jan 26 2013 2:35pm
DrLex
Iceland
Yellow or red?
Yellow is ok; red not so. Coincidental that it occurs the day after you have an unsatisfactory 4 wheel alignment, no?
Post #371046 Sat Jan 26 2013 4:32pm
jakeob
Sorry i should have said,,, Its Yellow
I was thinking the same thing about those tools messing around yesterday,,,, But it did it a couple of weeks ago a couple of times,, but cleard itself with the ignition on and off,,
Post #371047 Sat Jan 26 2013 4:47pm
PEACHY
Does the air suspension compressor sound noisy it's situated on the passenger side rear - just in front of the rear wheel. They are known to fail - I had the same symptoms as yourself for about 3 months until it finally went altogether ? 16MY Estoril Blue SVR.............
Post #371050 Sat Jan 26 2013 5:22pm
jakeob
No theres no noise at all,,, Out of interest how many miles did you do before it went all together??
Post #371055 Sat Jan 26 2013 6:52pm
PEACHY
Not many - I only do about 6k a year in the RRS. It was an intermittent fault then 1 day it just stayed on yellow - I reset the fault but it remained yellow. We disconnected the compressor then reconnected to see if it changed anything but the car just bottomed out - the only solution was to replace the compressor. I could tell that the one that was removed had already been refurbed. It's been fine since. Others might be able to put you in the right direction but if its noisy its probably on its way out.
Sad 16MY Estoril Blue SVR.............
Post #371057 Sat Jan 26 2013 7:30pm
Zippy
The same thing happened to me today too. Got home turned the car off came back out and the light did not not come back on same again there is no noise from the compressor ?
Post #371111 Sun Jan 27 2013 5:53pm
jakeob
My back end has now dropped to the stopps,,,, just drove the last 600 miles to my destination in france...
Now i need to try and get it fixed out here,,, any advice would be great
Post #371232 Mon Jan 28 2013 5:58pm
Bodsy
Site Sponsor
it definatley sounds like a new compressor is needed.
In all liklihood, it will be cheaper to get The Large One AKA Nick Lee @ Yeovil Landrover to send you a compressor and relay out and then you can get a local Indi out there to change it over. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #371236 Mon Jan 28 2013 6:07pm
jakeob
That could be an option, i will try to contact him,,,
Cheers for that
Post #371245 Mon Jan 28 2013 7:29pm
jakeob
Found a very helpfull and freindly LR dealer in Valance who fitted a new compressor+relay Cost 730 euro car now running fine.
One thing i have noticed when i turn the car off after a few seconds i get a short blast of air at the rear,,, it doesnt sound like leaking air , more of a controled blast,,
Is this normal???? i am 200km from the dealer now
Post #371830 Fri Feb 01 2013 9:46am
Bodsy
Site Sponsor
yes, it's the 'fart' releases a little pressure then it gets ready to self level. Thumbs Up perfectly normal.
If the fart turns to a hiss, then yoiui have problems.... Bodsys Brake Bible
See it HERE
Post #371848 Fri Feb 01 2013 11:00am
