Home > General > More problems
ShooterNeil
More problems
My car is falling apart around me
Week1 battery fails
Week2 car not used
Week3 stiff steering lower uj
Week4 uj replaced Wednesday after asking it to be fixed
Along with drivers door lock not working
Picked it up and airbag light is on not one button on the steering wheel works
Went out tonight and got 1 mile up the road alternator has failed
And door lock still not fixed its driving me mad never had a car with so much go wrong with it before
Post #367275 Thu Dec 20 2012 11:29pm
Welcome to the world of British-built cars. Big Cry
With Land Rover products, you either get a peach or a rotten apple. Their reliability reputation tells you all you need to know about how far they've got the ratio of those wrong! In a recent straw poll on this forum, the ratio was 6:4 peach:rotten apple. That just isn't good enough in a premium product. 2012 SDV6 - it's missing a couple of cylinders
Post #367276 Thu Dec 20 2012 11:49pm
sorry to hear your having so many problems Neil.
The altenator/battery issues were probably linked and not dianosed properly in the first place? RRS gone
Post #367281 Fri Dec 21 2012 9:02am
ShooterNeil
Garage won't help
And I can't get the fan off to change the alternator
Post #367293 Fri Dec 21 2012 11:11am
simple1
Is this a new car to you?
Think from memory the fan nut is 36mm and is a reverse thread so maybe why your struggling. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #367331 Fri Dec 21 2012 2:51pm
Disco_Mikey
Yes, 36mm and opposite thread.
Post #367337 Fri Dec 21 2012 3:27pm
ShooterNeil
Yes 36 mm it was just stuck fast
But car now will not start
Feel like burning it but house would go up to 😁😁😁😁😁😁😁
Post #367342 Fri Dec 21 2012 3:47pm
simple1
If the Ecu detects a massive drain such as a shorted out alternator, it will shut down. Not uncommon. Need to be a bit more aggressive with it. Special tool No 7, also known as large hammer, and not your claw hammer from kitchen cupboard! 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #367386 Fri Dec 21 2012 10:21pm
ShooterNeil
Blow lamp and big copper hammer got the fan off
Car was running ok but with battery light on before I stripped the old alternator off new one fitted
Now just turns over and will not start
Post #367392 Fri Dec 21 2012 10:59pm
simple1
Can't remember on V6 if there is front pulley sensor. Have a good look round areas you worked in to make sure all is plugged as should be. Whistle
Failing that need to plug it in to computer. I trust you had keys in pocket when battery was disconnected and reconnected?????
No idea what area you are in, I have a Verus if you are within reasonable drive from Bath.
Very Happy 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #367393 Fri Dec 21 2012 11:06pm
simple1
Tamworth is just a bit too far, just seen your avatar Sad 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #367394 Fri Dec 21 2012 11:08pm
ShooterNeil
Yes key was in my pocket next to car or with in less than 10 feet all day
Plan in the morning is to put battery on charge
Then look over were I worked
Put battery back on turn key to II
wait 5/10 min to see if it resync's with ECU
Thanks
Neil
Post #367396 Fri Dec 21 2012 11:29pm
simple1
If it locks and unlocks the car on normal key should still be sync'd. Not up to speed on keyless go systems but know its possible to confuse any key when reconnecting battery if in ignition 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #367397 Fri Dec 21 2012 11:38pm
ShooterNeil
It's only a 2005 so not keyless
Post #367399 Fri Dec 21 2012 11:56pm
ShooterNeil
As soon as it starts and faults cleared its going
I will be back to Jap cars
Shud of never sold my Evo IX
Post #367400 Sat Dec 22 2012 12:00am
