Home > General > More problems |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Welcome to the world of British-built cars.
Thu Dec 20 2012 11:49pm |
sorry to hear your having so many problems Neil.
Fri Dec 21 2012 9:02am |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
Garage won't help
Fri Dec 21 2012 11:11am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Is this a new car to you?
Fri Dec 21 2012 2:51pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4396 |
Yes, 36mm and opposite thread. |
Fri Dec 21 2012 3:27pm |
Yes 36 mm it was just stuck fast
Fri Dec 21 2012 3:47pm |
If the Ecu detects a massive drain such as a shorted out alternator, it will shut down. Not uncommon. Need to be a bit more aggressive with it. Special tool No 7, also known as large hammer, and not your claw hammer from kitchen cupboard! 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Dec 21 2012 10:21pm |
Blow lamp and big copper hammer got the fan off
Fri Dec 21 2012 10:59pm |
Can't remember on V6 if there is front pulley sensor. Have a good look round areas you worked in to make sure all is plugged as should be.
Fri Dec 21 2012 11:06pm |
Tamworth is just a bit too far, just seen your avatar 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Dec 21 2012 11:08pm |
Yes key was in my pocket next to car or with in less than 10 feet all day
Fri Dec 21 2012 11:29pm |
If it locks and unlocks the car on normal key should still be sync'd. Not up to speed on keyless go systems but know its possible to confuse any key when reconnecting battery if in ignition 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Dec 21 2012 11:38pm |
It's only a 2005 so not keyless |
Fri Dec 21 2012 11:56pm |
As soon as it starts and faults cleared its going
Sat Dec 22 2012 12:00am |
