Home > In Car Electronics > GVIF ADD ON ? |
No problem buddy there's always something else to add Bodsys Brake Bible
Thu Dec 20 2012 8:00pm |
Mitchmx Member Since: 22 Jul 2012 Location: Bristol Posts: 156 |
Is this the jizmo you need fitted to be able to listen to music off you I phone? Best quality. |
Thu Dec 20 2012 9:04pm |
You can use it for that as well, yes. It's basically an A/V device with reverse camera function.
Thu Dec 20 2012 9:24pm |
Nice. how much dose this cost? Do I have to get the phone module and most cable or will it do that as well?
Thu Dec 20 2012 9:37pm |
That's completely different Mitch.
Thu Dec 20 2012 9:47pm |
Cheers |
Thu Dec 20 2012 9:54pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
I'll stand by to be corrected,but I'm pretty sure the gvif still puts audio out via the aux input in the car.Mine does anyway maybe it's been updated?if you want iPhone music just get a Bluetooth receiver with a 3.5mm out,£20 off eBay will see it done. |
Fri Dec 21 2012 9:39am |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
Bodsy,
Fri Dec 21 2012 11:52am |
Mr Fixit, You are correct in that the sound is via AUX, but not via a cable showing to the Aux In, I wire it directly to the loom to minimise wires being visible.
Fri Dec 21 2012 7:31pm |
Daiboy Member Since: 16 Dec 2012 Location: Wales Posts: 4 |
Hi guys I am after a bit of help with gvif install all gone ok thanks to the rrs guide (thanks guys) problem is when using the override switch (primarily for eyeing up talent in car behind at traffic lights) the screen goes blank, if reverse is selected the picture appears, any help would be much appreciated.
Fri Feb 22 2013 5:27pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
Bodsy may correct me - but on mine you have to disconnect the cable from the unit and put it into another av connection on the GVIF unit - I did look at purchasing a splitter but never got round to it it's basically 1 or the other you can't have both - please please somebody tell me different 16MY Estoril Blue SVR.............
Fri Feb 22 2013 6:44pm |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
This is how I have wired up my camera.
Fri Feb 22 2013 6:47pm |
Daiboy,
Sat Feb 23 2013 8:17am |
In my configuration you do not need a splitter and you do not use an extra AV input, only the reverse camera one.
Sat Feb 23 2013 8:31am |
