Home > In Car Electronics > GVIF ADD ON ?
Bodsy
Site Sponsor
Ah right, you've got a live to fool th gvif into thinking its in reverse Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #374442 Sat Feb 23 2013 8:37am
flydive
Correct Thumbs Up '08 RRS TDV8
Post #374443 Sat Feb 23 2013 8:42am
Daiboy
Bodsy/fly dive you are both up there with the greats, Brunel, Einstein , Baird, I need to get some supplies to do either option.
Will update as and when
Thx again
Daiboy New owner very pleased with it......
Post #374446 Sat Feb 23 2013 9:45am
I have a problem.
The cable that picks up the loom and feed to the back of the GVIF seams to be faulty (at the LR end of the cable)
Is the wiring of this plug simple? Or can a replacement be located?
I've spoken to HIDS4U and the new design has a Y cable with a single 6 connector plug, whereas mine has the older twin cables with 3 pins on each. RRS gone
Post #375078 Thu Feb 28 2013 9:42am
Louiscypher
2009 Range Rover Sport TDV6 HSE Bourneville
Bodsy wrote:
No problem buddy Thumbs Up there's always something else to add Mr. Green Thumbs Up
Bodsy,
I'd really like the reversing camera and happy to travel up to your neck of the woods - would you be able to provide a price to supply and install a solution (and any other goodies you think a 2009 RRS 2.7TDV6 might need)?
Cheers,
Adrian '10 RRS 5.0 SC
'13 Cayman S
Post #377236 Sun Mar 17 2013 8:41pm
tanloverluke
hi,
looks like there are a few great minds on this thread. i'm about to buy a gvif unit but Bodsy, you write that for the reverse camera function to work you must be on the satnav screen. i'm rarely on that screen, usually on the home screen in fact or using the rear entertainment system for the kiddy.
i see you guys have been discussing various work arounds so question is, will it be possible to use the reverse camera function regardless of what screen im in ?
i'm living in devon and not so keen on having to drive hundreds of miles to get this done. is it a simple job (given i have clear instructions, dont mind paying for assistance Mr. Green )?
Cheers / Luke Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #392250 Mon Aug 19 2013 7:26pm
flack
@tanloverluke
When you use a Gvif unit you must be on the map screen to see the reversing camera image when selecting reverse as its an overlay of the map screen, you could use one of the other AV in's but you would need to select the av that you connected the rear view camera to so you can see the image.
Flack Thumbs Up
Post #392252 Mon Aug 19 2013 7:42pm
tanloverluke
thanks for that. i see on the gvif unit that there is a dedicated reverse camera input cable. are you saying then that if i select one of the other 3 av inputs that the image will appear regardless of what screen im in.
there was me thinking that the reverse camera function "took over" the screen until reverse was deselected Sad Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #392266 Mon Aug 19 2013 9:00pm
RRS_Supercharged
Bodsy,
Out of interest how much do you charge to fit a reversing cam and GVIF?
I have just bought my first RRS and would like to have this done.
Regards
Post #393839 Thu Sep 05 2013 11:28am
