![]() | Home > Maintenance & Modifications > Range Rover Sport Subwoofer Build Underway ! |
Thehos Member Since: 24 Jul 2016 Location: Somerset Posts: 123 ![]() ![]() |
I'd like some more information as well please
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
I had the same issue of vibration and rattle but both are relatively easy to fix and I have put a post in tips and tricks to explain. |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
When I used to drive a Saab, 'the done thing' in that situation was to wind-down the windows, blast out the theme from The Archers and politely acknowledge the youngsters with a raise of a briar pipe whilst zooming past them. |
This guy has a rotary subwoofer with his living-room as a box. |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
Nice work!!!
It's easy, the only pain in the butt is removing and replacing the trim. Take the opportunity to dampen the surfaces and sub cavity as well. |
