Home > Maintenance & Modifications > Range Rover Sport Subwoofer Build Underway !
karan538
2008 Range Rover Sport TDV6 HSE Santorini Black
So, those of you who have heard the terrible subwoofer in the range rover surely know it needs a upgrade. The harmon Kardon logic 7 sounds crystal clear but the subwoofer sucks.
So I'm removing the stuff from my mercedes and installing it in the range. I will be putting a more heavy system in the mercedes while my current stuff will do the job for the range. So heres how its going..
Amplifier:
500W x 1 RMS @ 4 Ohm bridged
750W x 1 RMS @ 2 Ohm bridged / 1500W MAXIMUM POWER
THD <0>98db
T.D.O.S. Amplifier Protection Circuitry
O.P.S. Oversized Power Supply
200MV – 6V Ready Pre-Amp Input Stage
Ultra Low THD Audiophile Components
High Density Cast Aluminium Heatsink Body
Thermally Efficient Heatsink Coating
50-250hz Variable Low-Pass Crossover
15-50hz Variable Sub Sonic Filter
Line output for daisy chain amplifier applications
Subwoofer:
Dimensions - H x W x D: 43.5x46.5x40cm
Frequency Response: 20Hz-850Hz
Impedance: 4ohm
Peak Power: 1500w
RMS Power: 500w
Sensitivity: 92dB
Type: Sub Enclosure
Yes the two things above are not the best, they are cheap. But they still do the job, shake your car up, and give you a clean sound. Obviously its nothing compared to the more real stuff.
Perfect place to install the amp is under the seat. Hides away all the wires and does not take boot space. Also you can access it easily by just pulling the seat up
Rooting the power cable to the front. Tucking away the wire deep inside the plastic.
A closer picture to the front near the pedals, the wire will go into the firewall to the engine bay, where obviously it will connect to the battery
The car
Subwoofer at the back:
Also I installed those tv screens myself Smile
The build is not finished yet so watch out for other pictures. Will also upload a video of how it looks finally and also how it sounds.
Very Happy
What do you guys think, anything I should do diffrently or anything else I should add in?
Post #365791 Fri Dec 07 2012 7:33pm
Adam RRS
Looks great
how do you connect up to the standard headunit though? Thats the reason I havent upgraded. WINNER - 2009 Best in Class Range Rover Sport Award
MY14 Corris Grey RRS HSE SDV6
Post #366176 Mon Dec 10 2012 5:46pm
If it didn't look like a big ugly box in the boot,it would be a good upgrade Shocked
Might sound better but needs to be built in and hidden for my taste Thumbs Up
Post #366179 Mon Dec 10 2012 6:34pm
I'm with npinks.
Love the comment about putting the amp under the seat which saves room in the boot. And then a blinking great box of a speaker is put in there.
Is it not possible to get a sub that would also go under the seat or perhaps under the boot floor in place of the tool tray? 2012 SDV6 - it's missing a couple of cylinders
Post #366184 Mon Dec 10 2012 7:41pm
mse
Me two...why you want to loose the boot wich a massive box for a bit extra bass escapes me personally Mike
2014 Facelift Discovery
Post #366188 Mon Dec 10 2012 8:32pm
karan538
@adam. you use a high to low converter and splice into the wires already going to the factory sub and connect your converter. it just uses a bunch off resistors to just give you the rca output you want instead of the amplified signal. as for the remote wire, just use the ciggy lighter Wink
yeah i have seen a lot of people fiberglassing there own custom enclosures and putting it in the boot floor but thats to much for me. i just wanted extra bass and dont mind the space its taking. Not like its screwed in I can just pull it out when i need the extra space.
and believe me, the box is a mouse compared to the proper bass enclosures out there! i guess it just comes down to personal taste
Post #366214 Tue Dec 11 2012 12:08am
Same here Confused ON THE WAY: BMW F21 M140i
Post #366215 Tue Dec 11 2012 12:16am
SRE
Spain
Bet your next mod is to fit a roof box Rolling with laughter In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #366240 Tue Dec 11 2012 10:01am
Out of interest, where is the current sub? or does the bass rely on the large door cones RRS gone
Post #366255 Tue Dec 11 2012 12:33pm
mse
Tailgate door behind the carpet Mike
Post #366264 Tue Dec 11 2012 3:55pm
Adam RRS
Ahh thats clever! Some car audio shop told me its £500 for a digital box that converts the signal! I politely passed on that one. WINNER - 2009 Best in Class Range Rover Sport Award
Post #366280 Tue Dec 11 2012 4:58pm
To be honest, i think the standard stereo is more than adequate for the sport. Its not the sort of motor you usually see driving around town centres with its windows thumping away.
Post #366297 Tue Dec 11 2012 8:44pm
What happened to tha Ajp chap, I recon he'd appreciate a 'banging' sound system Laughing ON THE WAY: BMW F21 M140i
Post #366300 Tue Dec 11 2012 9:33pm
rigsby
At least you will never have the old knocking suspension problem Thumbs Up MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #366310 Tue Dec 11 2012 10:27pm
Cupra
so thats why the local boyracers gave me funny looks at the traffic lights with a bit of ELO blasting out drowning their "Xfactors rejects CD "
Post #366441 Wed Dec 12 2012 8:04pm
