![]() | Home > General > Changed to L.E.D. |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
Finished off my interiors and side lights today, headlights were a doddle |
Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282 ![]() ![]() ![]() |
I had the exact same problem with the passenger side rear map light, the holder came right out, after fiddling a little I pulled the cable and it came out enough to re connect it |
Glad i'm not the only one, it took me ten minutes of finger fidling (pardon the expression) before i managed to reconnect.
2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
I've lost the rear door puddle light connector on the passenger side...I'll be |
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 ![]() ![]() ![]() |
Are all the bulbs in the sports the same type? Boot lights, roof lights, puddle lights, glovebox lights, the whole lot?
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
2 front footwell (interior) lights ![]() 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
T5 or 268 bulbs converted to LED...
Mr Pimp, the lights mentioned above are all the same W5W fitment. The sun visor lights I posted above are T5 or 268 bulbs. The 2 front sidelights are also W5W Hope this helps ![]() |
So changed all my interior except for the vanity mirror ones. Also did rear number plate lights. Massive improvement and looks great.
davidjrr Member Since: 24 Nov 2012 Location: Nottingham Posts: 4 ![]() ![]() ![]() |
this is a good idea..will have mine changed in a few days as well..thanks guys |
Changed the vanity mirror lights tonight, what a difference |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
Hiya, can i ask white colour t5 bulbs you got was they xenon white ? |
Deuchars Member Since: 26 Jul 2015 Location: North Wales Posts: 38 ![]() ![]() ![]() |
I've just done my side lights, great improvement. Waiting for more led's to arrive from flea bay, but only ordered 10, so I'm guessing I'm going to be a few short....
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 ![]() ![]() ![]() |
They will certainly give a bulb fault error message. You need at least bulbs with built-in resistors (they suck, as the resistors get hot and eventually fail), I would rather suggest a stand-alone module like this one: http://www.horizonleds.co.uk/led-headlight...ree-module - I've used a similar solution in my LED side marker upgrade and have zero errors. Bear in mind, that while they will look bright and will have a perfect colour, the LED H7 and H8 replacements emit much less luxes compared to regular bulbs and you will actually have worse high beam than before. Probably less noticeable with cornering lights, but I'd definitely install a "superwhite" regular H7 from Osram or other respected brand and not a LED. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE Last edited by TheWojtek on Sat Aug 29 2015 1:03am. Edited 1 time in total |
