Home > General > Changed to L.E.D.
Page 2 of 3 <123>
Big ken
Scotland 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Much better Thumbs Up 2.7 TDV6
22" Stormer alloys
Side steps
PS3
Headrest monitors
Black badges
Stainless tailpipes
Privacy glass
L.E.D. lights throughout.
Post #363450 Sat Nov 17 2012 1:23pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Finished off my interiors and side lights today, headlights were a doddle Thumbs Up
Had a bit of an issue with one of the rear reading lights because when removing the light fitting it separated from the connector within the head liner and it was a real pain to reconnect.
The only bulbs I haven't done are the ones that shine when indicating at slow speeds, anyone recommend a replacement?
Nik. 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #363460 Sat Nov 17 2012 3:54pm
Big ken
I had the exact same problem with the passenger side rear map light, the holder came right out, after fiddling a little I pulled the cable and it came out enough to re connect it Bow down 2.7 TDV6
22" Stormer alloys
Side steps
PS3
Headrest monitors
Black badges
Stainless tailpipes
Privacy glass
Post #363468 Sat Nov 17 2012 4:38pm
Nik
Glad i'm not the only one, it took me ten minutes of finger fidling (pardon the expression) before i managed to reconnect.
Nik
 2015 Golf R DSG
Post #363473 Sat Nov 17 2012 5:09pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
I've lost the rear door puddle light connector on the passenger side...I'll be Censored if i ever see it again Laughing
Post #363474 Sat Nov 17 2012 5:12pm
big pimp
Are all the bulbs in the sports the same type? Boot lights, roof lights, puddle lights, glovebox lights, the whole lot?
I've a 2010 - how many bulbs will I need? I'm guessing:
Boot
Number plate
2 rear map lights
2 rear puddle lights
2 front puddle lights
3 overhead cabin lights
1 glovebox light
Is this right? Have I missed any? What is the link to the bulbs - are they the multi led bulbs linked to in the first page here?
Thanks in advance MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #363626 Sun Nov 18 2012 11:53pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
Boot
Number plate
2 rear map lights
1 glovebox light
Thanks in advance
2 front footwell (interior) lights Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #363627 Mon Nov 19 2012 12:22am
kav1187
T5 or 268 bulbs converted to LED...
Sun visor lights before
Sun visor light cover removed
Sun visor light bulb removed
T5 LED
Difference between normal bulb and LED
After Cool
Post #363813 Tue Nov 20 2012 4:42pm
kav1187
Boot
Number plate
2 rear map lights
1 glovebox light
Thanks in advance
Mr Pimp, the lights mentioned above are all the same W5W fitment. The sun visor lights I posted above are T5 or 268 bulbs.
The 2 front sidelights are also W5W
Hope this helps Thumbs Up
Post #363814 Tue Nov 20 2012 4:45pm
big pimp
So changed all my interior except for the vanity mirror ones. Also did rear number plate lights. Massive improvement and looks great.
Only problem is driver and passenger front puddle lights must be on a different circuit as they only work then the sport is running. If I open the doors they don't come on but all the rest (including rear door puddle lights) do come on.
Also, like right now if I open the door when the sport is running they power fine but as soon as I press the start / stop button and the car powers down all lights except the front door puddle lights come on.
I'm puzzled but does anyone have any ideas or suggestions?
Post #364559 Mon Nov 26 2012 6:07pm
davidjrr
United Kingdom 2009 Range Rover Sport 4.4 V8 Java Black
this is a good idea..will have mine changed in a few days as well..thanks guys
Post #364933 Thu Nov 29 2012 7:05pm
Big ken
Changed the vanity mirror lights tonight, what a difference Shocked 2.7 TDV6
22" Stormer alloys
Side steps
PS3
Headrest monitors
Black badges
Stainless tailpipes
Privacy glass
Post #365127 Sat Dec 01 2012 11:28pm
Wayneclarke
T5 LED
After Cool
Hiya, can i ask white colour t5 bulbs you got was they xenon white ?
Post #471146 Wed Aug 26 2015 7:58pm
Deuchars
Wales 2008 Range Rover Sport Supercharged HSE Stornoway Grey
I've just done my side lights, great improvement. Waiting for more led's to arrive from flea bay, but only ordered 10, so I'm guessing I'm going to be a few short....
Does anyone know if there are any canbus problems with replacing the H7 high beam, and H8 corner light with Led bulbs, and the indicator bulbs for that matter? 2008 Supercharged Stornaway Grey, 22inch black Stormers
Full led light pack, HST front grill, black lettering....
Great to be back on Petrol.....
Mini Cooper SD......New arrival
Nissan Navarra....gone
Mercedes C320 cdi...gone
Mini Cooper D....
Subaru Impreza Sti....gone
Land Rover Discovery....gone
Many more over the years...all gone...
Post #471230 Thu Aug 27 2015 7:39pm
TheWojtek
They will certainly give a bulb fault error message. You need at least bulbs with built-in resistors (they suck, as the resistors get hot and eventually fail), I would rather suggest a stand-alone module like this one: http://www.horizonleds.co.uk/led-headlight...ree-module - I've used a similar solution in my LED side marker upgrade and have zero errors.
Bear in mind, that while they will look bright and will have a perfect colour, the LED H7 and H8 replacements emit much less luxes compared to regular bulbs and you will actually have worse high beam than before. Probably less noticeable with cornering lights, but I'd definitely install a "superwhite" regular H7 from Osram or other respected brand and not a LED. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #471234 Thu Aug 27 2015 8:17pm
Page 2 of 3 <123>
