Home > Technical > PARKING SENSORS NOT WORKING
merwiz
If the sensor that you want to change is on the OUTSIDE edge of the front bumper, you can change it without removing the bumper.
If it's one of the two centre sensors, than the bumper has to come off. I keep telling myself 'It's a toy'
But I've broken quite a lot of toys in my time.....
Post #299640 Mon May 16 2011 3:45pm
DAINEWBOY
Wales 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Flaming typical I got one on the side and one in the centre. Suppose I should just take it off RRS 07
VW POLO MK6
VW R32 MK5 GONE BUT NOT FORGOT
Post #299669 Mon May 16 2011 7:31pm
DAINEWBOY
If I spray these sensors will it affect them working
I mean if I get paint or clear laquer in the middle bit of the sensor.??????????? Sheep RRS 07
VW POLO MK6
Post #299670 Mon May 16 2011 7:32pm
DAINEWBOY
just had the new sensors fitted. i thought i could get away with not taking the front bumber off, but i was wrong. had to take it all off. managed to change one sensor without taking the bumber off but had to take it off for the centre one.
while th bumber was off i found that there is corrossion on the back of the front fogs and that there was a wire that had rusted away on one of the sensors, had the sparky at the garage to check all other wires and fix the broken one.
all back on and working ok.
thanks for all the help and advice guys.
Thumbs Up Bow down Sheep Sheep Sheep Sheep Sheep RRS 07
VW POLO MK6
Post #299777 Tue May 17 2011 5:28pm
jwg
Scotland
i cant seem to get any clicking from any of the sensors on my car
does the engine need to be running hand brake of in drive and foot on the brake to hear them clicking ? jwg
Post #423023 Thu May 01 2014 7:55pm
DAINEWBOY
I just had the handbrake on turned the ignition to the on position and put it in to reverse. Then went around all the sensors listening to them.
I think I tried it with the engine running to, but it worked with just the ignition turnd to the on position.
If you have a stethoscope then this would amplifie the sounds but I didn't use one, the sparky had one think he was in to playing doctors and nurses.
Good luck RRS 07
VW POLO MK6
Post #423029 Thu May 01 2014 8:34pm
dab130283
United Kingdom 2005 Range Rover Sport TDV6 HSE Adriatic Blue
I was told the front bumper has to come off as one of mine was faulty. So I had a look and could not get it out from getting my hand up behind. So since the sensor was faulty I hit it with a big centre punch and pushed it in then removed the other surround fished the broken sensor through the hole removed wiring and fitted new one job done only took about half hour to do.
Post #423086 Fri May 02 2014 11:22am
dab130283
This was a centre sensor too
Post #423087 Fri May 02 2014 11:26am
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
can you paint the sensors or how do I do this to get it in the cars color?
Post #423315 Mon May 05 2014 10:43pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
My front left sensor is dead. So how do you change it without taking the bumper off? Is there a bolt inside the wheel well you need to loosen? I know it's faulty as the sound is not on it. So was tempted to just drill it out but a big punch might be even better. Great idea Smile
Post #423317 Mon May 05 2014 10:49pm
