Home > Technical > PARKING SENSORS NOT WORKING |
merwiz Member Since: 26 May 2009 Location: Wirral Posts: 143 |
If the sensor that you want to change is on the OUTSIDE edge of the front bumper, you can change it without removing the bumper.
Mon May 16 2011 2:45pm |
DAINEWBOY Member Since: 10 May 2011 Location: Aberdare Posts: 50 |
Flaming typical I got one on the side and one in the centre. Suppose I should just take it off RRS 07
Mon May 16 2011 6:31pm |
If I spray these sensors will it affect them working
Mon May 16 2011 6:32pm |
just had the new sensors fitted. i thought i could get away with not taking the front bumber off, but i was wrong. had to take it all off. managed to change one sensor without taking the bumber off but had to take it off for the centre one.
Tue May 17 2011 4:28pm |
I just had the handbrake on turned the ignition to the on position and put it in to reverse. Then went around all the sensors listening to them.
Thu May 01 2014 7:34pm |
dab130283 Member Since: 08 Dec 2013 Location: Kent Posts: 16 |
I was told the front bumper has to come off as one of mine was faulty. So I had a look and could not get it out from getting my hand up behind. So since the sensor was faulty I hit it with a big centre punch and pushed it in then removed the other surround fished the broken sensor through the hole removed wiring and fitted new one job done only took about half hour to do. |
Fri May 02 2014 10:22am |
This was a centre sensor too |
Fri May 02 2014 10:26am |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 |
can you paint the sensors or how do I do this to get it in the cars color? |
Mon May 05 2014 9:43pm |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
My front left sensor is dead. So how do you change it without taking the bumper off? Is there a bolt inside the wheel well you need to loosen? I know it's faulty as the sound is not on it. So was tempted to just drill it out but a big punch might be even better. Great idea |
Mon May 05 2014 9:49pm |
