Home > Technical > Car wont start !
raymondnicol
United Kingdom 2006 Range Rover Sport TDV6 HSE Lugano Teal
Car wont start !
I recently payed £7000 to get my car fixed : full top end i.e pistons,rings,heater plugs,valves, timing chain etc. and the mileage was only 82,000 now i have the car back it has broken down 4+ times in 2 month Land Rover took it back in to check problems through a diagnostic check nothing is coming up. The problems are when it put the key in the ignition the doors lock the hazards come on and the engine doesnt start the faults come on the screen are limited gear selection transmission failure, dsc failure, hdc failure, suspension lowered, transmission fault traction reduced, engine system fault, park brake fault auto release not functional all the lights on the dash/dials come on red + orange and the temp goes sky high and the red dot goes on but on sometimes the car starts and runs fine. 06 plate 2.7 tdv6 hse.
Post #283998 Fri Dec 24 2010 5:22pm
DSL
At a guess from similar on D3 site battery is goosed, either on it's own or because alternator is similarly goosed.
Post #283999 Fri Dec 24 2010 5:29pm
raymondnicol
do you think this has anything to do with the work they have already done or just wear and tear? much was it to fix your d3? you get no help from stratstone think the next car will be a chiquichento haha
Post #284000 Fri Dec 24 2010 5:40pm
DSL
Afraid I'm a non techie so no idea, just a lot of similar problems at the mo with D3s, a RRS being a D3 in drag.
Post #284001 Fri Dec 24 2010 5:47pm
Misery
Shocked Shocked Shocked Shocked why did you have to have all that done????
Post #284002 Fri Dec 24 2010 5:48pm
raymondnicol
thanks alot m8
Post #284003 Fri Dec 24 2010 5:49pm
raymondnicol
the tensioner jumped it needed fixed what started of a fuel pump problem by an aa technician ended up a £7000 head sore .
Post #284004 Fri Dec 24 2010 5:51pm
Misery
Silk purse from pigs ear. Wink Wink
Post #284056 Sat Dec 25 2010 2:07pm
DSL
Ner Ner Thumbs Up
Post #284061 Sat Dec 25 2010 7:17pm
Misery
Laughing Whistle
Post #284075 Sat Dec 25 2010 10:43pm
raymondnicol
found out my problem it was a corroded wire in the harness hope it helps someone
Post #285580 Tue Jan 11 2011 3:59pm
