Home > Technical > Car wont start ! |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 |
At a guess from similar on D3 site battery is goosed, either on it's own or because alternator is similarly goosed. |
Fri Dec 24 2010 5:29pm |
raymondnicol Member Since: 24 Dec 2010 Location: Scotland Posts: 8 |
do you think this has anything to do with the work they have already done or just wear and tear? much was it to fix your d3? you get no help from stratstone think the next car will be a chiquichento haha |
Fri Dec 24 2010 5:40pm |
Afraid I'm a non techie so no idea, just a lot of similar problems at the mo with D3s, a RRS being a D3 in drag. |
Fri Dec 24 2010 5:47pm |
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 |
why did you have to have all that done???? |
Fri Dec 24 2010 5:48pm |
thanks alot m8 |
Fri Dec 24 2010 5:49pm |
the tensioner jumped it needed fixed what started of a fuel pump problem by an aa technician ended up a £7000 head sore . |
Fri Dec 24 2010 5:51pm |
Silk purse from pigs ear. |
Sat Dec 25 2010 2:07pm |
Sat Dec 25 2010 7:17pm |
Sat Dec 25 2010 10:43pm |
found out my problem it was a corroded wire in the harness hope it helps someone |
Tue Jan 11 2011 3:59pm |
