Home > Technical > RRS Side Step DIY installation
Nickleback
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Has anyone got any details, links, instuctions or pictures on how to install OEM LR side steps to a RRS 07 HSE. as I have found some good used ones but now need to install them correctly.
I have all the brackets & bolts etc, just need the method & pics of how to do it etc as I cant find anything on the www ? I am their leader................ which way did they go ?
Post #243287 Sat Nov 21 2009 11:41am
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
A search would have bring you to this link:
http://www.ownerinfo.landrover.com/extfree2viewlrprod/index.jsp Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #243290 Sat Nov 21 2009 12:31pm
Nickleback
Sorry Jimmy, but how does that help ? (I've obviously missed something?) I am their leader................ which way did they go ?
Post #243314 Sat Nov 21 2009 6:12pm
acowx
United States 2006 Range Rover Sport Supercharged Rimini Red
The side step installation instructions are in PDF format under the "Accessory Fitting Instructions" on that page.
Post #243324 Sat Nov 21 2009 7:37pm
Jimmy_75000
As ACOWX mention. This is the land rover source for accessoriees manual, car manual.... Range Rover Vogue ‘17 TDV6
Post #243358 Sun Nov 22 2009 11:59am
SimonH
Nickle
You have a pm.
Post #243382 Sun Nov 22 2009 8:21pm
Nickleback
I tried to subscibe but it would'nt let me.
Will try again !
Thanks for your help
Cheers I am their leader................ which way did they go ?
Post #243385 Sun Nov 22 2009 9:07pm
Nickleback
SimonH wrote:
Nickle
You have a pm.
Thanks Simon, you have PM I am their leader................ which way did they go ?
Post #243386 Sun Nov 22 2009 9:09pm
Jimmy_75000
Will try again !
You don't have to subscribe. Just select your car on the top left, then accessory fitting instruction in the second box and off you go...
Sometime, the browser you are using might cause an issue...better to avoid Safari (mac) and use firefox Range Rover Vogue ‘17 TDV6
Post #243402 Mon Nov 23 2009 8:05am
Nickleback
Jimmy_75000 wrote:
Will try again !
Thanks very much, sorted
Post #243497 Mon Nov 23 2009 9:37pm
alid32
2007 Range Rover Sport TDV6 HSE Zambezi Silver
I wanted to fit some side steps.... but looking at those instructions, i might leave it to the stealers Embarassed
Post #243617 Tue Nov 24 2009 7:16pm
