Home > Technical > RRS Side Step DIY installation |
Nickleback Member Since: 06 Oct 2009 Location: Down South Posts: 63 |
Has anyone got any details, links, instuctions or pictures on how to install OEM LR side steps to a RRS 07 HSE. as I have found some good used ones but now need to install them correctly.
Sat Nov 21 2009 11:41am |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
A search would have bring you to this link:
Sat Nov 21 2009 12:31pm |
Sorry Jimmy, but how does that help ? (I've obviously missed something?) I am their leader................ which way did they go ? |
Sat Nov 21 2009 6:12pm |
As ACOWX mention. This is the land rover source for accessoriees manual, car manual.... Range Rover Vogue ‘17 TDV6
Sun Nov 22 2009 11:59am |
SimonH Member Since: 18 Feb 2009 Location: York, North Yorkshire Posts: 54 |
Nickle
Sun Nov 22 2009 8:21pm |
I tried to subscibe but it would'nt let me. Will try again ! Thanks for your help Cheers I am their leader................ which way did they go ? |
Sun Nov 22 2009 9:07pm |
Thanks Simon, you have PM I am their leader................ which way did they go ? |
Sun Nov 22 2009 9:09pm |
You don't have to subscribe. Just select your car on the top left, then accessory fitting instruction in the second box and off you go... Sometime, the browser you are using might cause an issue...better to avoid Safari (mac) and use firefox Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Mon Nov 23 2009 8:05am |
Thanks very much, sorted Cheers I am their leader................ which way did they go ? |
Mon Nov 23 2009 9:37pm |
alid32 Member Since: 30 Oct 2009 Location: Lancs Posts: 12 |
I wanted to fit some side steps.... but looking at those instructions, i might leave it to the stealers |
Tue Nov 24 2009 7:16pm |
