Home > Technical > posessed automatic rear window. mind of its own
wo ping
Scotland
came back to my car today after work and found one of the rear windows open. If I try and close it it just reaches the top and goes straight back down again. I appreciate this is some sort of kiddie safety feature but surely the bloody window should close if theres no head in the way !!!
I knew I'd never see the first 1,000 miles trouble free. Censored new cars shouldn't have these problems if QA is any good.
I can't be arsed driving the 70 mile round trip to my dealer. is this a land rover assist job or will they tell me to get stuffed??
Brand new MY2010 RRS.
not chuffed.
Post #238603 Wed Sep 30 2009 10:57pm
RANGE_LOVER
Try and check to make sure that the trim is not blocking the window travel route. Or a foreign object has not lodged itself. Otherwise i think it may be a Land rover assist Job! Thumbs Up
Failing that contact: www.SpiritPortal.org Rolling with laughter Rolling with laughter
Post #238606 Thu Oct 01 2009 4:15am
Similar thread on freel2.com
see if the fix posted works on the RRS
http://www.freel2.com/forum/topic3132.html
Post #238610 Thu Oct 01 2009 6:32am
MAW
Good find NP Thumbs Up
Post #238620 Thu Oct 01 2009 7:15am
There is a similar window reset for the RRS too - although I don't remember if the steps are exactly the same Confused
Post #238622 Thu Oct 01 2009 7:18am
wo ping
Scotland
now chuffed Thumbs Up
worked a treat. many thanks !!
Post #238648 Thu Oct 01 2009 10:16am
Kilovolt
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
Just had to carry out this procedure on a MY10 FFRR Vogue and would you believe it, works on that as well Smile
Repeated here for good info:
Window reset.
The windows will need to be reset if the battery is disconnected, becomes discharged, or power supply is interrupted.
Reset as follows :-
1. Close the window fully.
2. Release the switch, then lift it to the close position and hold for two seconds.
3. Open the window fully.
4. Release the switch, then push it to the open position and hold for two seconds.
5. Lift and release the switch to operate the one touch function.
6. Repeat the procedure on each window.
Thanks very much. Smoke me a kipper: I'll be back for breakfast.
RRS HSE TDV6 gone after 15 months since new - will not be missed I'm afraid - bit of a gremlin in there somewhere - too many issues. Replaced with FFRR Vogue TDV8 - very nice - not as sporty (of course) but absolute luxury.
Post #254069 Sat Feb 06 2010 3:41pm
Josh
That fix could do with being put somewhere useful Moderators so it can be found easily Idea TDV6 - gone
TDV8 - gone
Post #254078 Sat Feb 06 2010 5:46pm
Bobby
If it still gives you a problem then it could be this, which might help...??? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #254090 Sat Feb 06 2010 9:15pm
Endjin
Scotland
Bow down Thumbs Up Just noticed 3 of my windows didn't one push close. Did the procedure as per FREEL2 and hey presto.. They are now all working Mr. Green Cheers NP Thumbs Up 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #254180 Sun Feb 07 2010 12:03pm
