Home > Technical > posessed automatic rear window. mind of its own |
RANGE_LOVER Member Since: 01 Jun 2009 Location: London Posts: 306 |
Try and check to make sure that the trim is not blocking the window travel route. Or a foreign object has not lodged itself. Otherwise i think it may be a Land rover assist Job!
Thu Oct 01 2009 4:15am |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
Similar thread on freel2.com
Thu Oct 01 2009 6:32am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Good find NP |
Thu Oct 01 2009 7:15am |
There is a similar window reset for the RRS too - although I don't remember if the steps are exactly the same
Thu Oct 01 2009 7:18am |
wo ping Member Since: 13 Feb 2008 Location: east lothian Posts: 30 |
now chuffed
Thu Oct 01 2009 10:16am |
Kilovolt Member Since: 26 May 2009 Location: South Derbyshire Posts: 50 |
Just had to carry out this procedure on a MY10 FFRR Vogue and would you believe it, works on that as well
Sat Feb 06 2010 3:41pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
That fix could do with being put somewhere useful Moderators so it can be found easily TDV6 - gone
Sat Feb 06 2010 5:46pm |
If it still gives you a problem then it could be this, which might help...??? Malaysia Boleh!
Sat Feb 06 2010 9:15pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Just noticed 3 of my windows didn't one push close. Did the procedure as per FREEL2 and hey presto.. They are now all working Cheers NP 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Sun Feb 07 2010 12:03pm |
