![]() | Home > Technical > posessed automatic rear window. mind of its own |
RANGE_LOVER Member Since: 01 Jun 2009 Location: London Posts: 306 ![]() ![]() ![]() |
Try and check to make sure that the trim is not blocking the window travel route. Or a foreign object has not lodged itself. Otherwise i think it may be a Land rover assist Job! |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Similar thread on freel2.com
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Good find NP |
There is a similar window reset for the RRS too - although I don't remember if the steps are exactly the same |
wo ping Member Since: 13 Feb 2008 Location: east lothian Posts: 30 ![]() ![]() |
now chuffed |
Kilovolt Member Since: 26 May 2009 Location: South Derbyshire Posts: 50 ![]() ![]() ![]() |
Just had to carry out this procedure on a MY10 FFRR Vogue and would you believe it, works on that as well |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
That fix could do with being put somewhere useful Moderators so it can be found easily |
If it still gives you a problem then it could be this, which might help...??? Malaysia Boleh!
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
