Home > Maintenance & Modifications > How can I solve the DPF problem and how can I remove it?
Page 5 of 5 <12345
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
Here is a better picture with all the relevent part numbers, only the front pipes and centre is needed, therear is the same on the DPF model.
The cats look expencive, may be an aftermarket exhaust company can make non cat versions. Smile
Pete
Post #220197 Sun Mar 29 2009 6:12pm
C10KO
Post #220199 Sun Mar 29 2009 6:17pm
bananenschale
Germany 2009 Range Rover Sport TDV8 HSE Santorini Black
sorry, but my english is not the best so i have to ask again:
its possible to remove the dpf, this i understand. i also need to remap the sensors, also ok. But what i need now?
Where´s the DPF on the picture?
Is it possible to measuring that the dpf is removed from the car? because, in germany we had an very good organisation, called TÜV. If the look under the car in 3 years and ask where the dpf is i couldnt answer anything. So perhaps i also would need an dummy or anything else.
last question:
is the car faster and quicker after removing the dpf? and what can be damaged after the removal?
thanks and sorry again for the questions Smile
bye tom RRS TDV8 Modelyear 2009 with some modifications.
Post #220314 Mon Mar 30 2009 2:59pm
C10KO
Tom,
but as far as I am aware when you remove the DPF the car does not get any faster (some will disagree with me Whistle ) . There is no technical reason why it should.
Now to TUV, this is a bit tricky. As I my car comes from Germany I also need to take the German “rules” into consideration.
When I did the research, I found that some say that DPF as such is not required to pass TUV and get the reduced tax, though others claimed that DPF is required for the reduced emission (crap).
To be on the safe site, talk to the local TUV directly and get it in writing before you remove it.
Even if you sort TUV, do not forget about LR Germany (spent hours talking to the “lovely b Censored ” over the phone). The official statement I got from them is do not do it under any circumstance.
Hmmm, I know that it is not of much help but that is where I came to halt. Big Cry
After exchanging the sensor inside the DPF, I am trying to get the car out for a longer drive at least once a week (useless and pricy recommendation) and have not had any fault for almost two month now. Thumbs Up
Post #220325 Mon Mar 30 2009 3:27pm
bellautos
The DPF is not in this picture which is why i posted it, for the people who want to remove it.
Yes you need ecu tuning done to remove it from the system electricly.
Pete
Post #220345 Mon Mar 30 2009 6:36pm
Bobby
the picture is here...
http://www.rrsport.co.uk/forum/post219096.html#219096
As I have mentioned elswhere, the vehicles come with DPF and non-DPF. Check with TUV if it is compulsory to have DPF (do all cars sold in Germany have DPF?). If not, then why would anybody ask you for it 3 years from now? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #220380 Mon Mar 30 2009 10:48pm
C10KO
Bobby, all LRs in Germany come with a DPF (authorities blame it on emissions)...
Post #220409 Tue Mar 31 2009 5:57am
Hangover
Belgium 2008 Range Rover Sport TDV8 HSE Alaska White
Is there a LR dealer who is willing to execute the exhaust/software conversion for my DPF equipped TDV8?
I've spoken to several dealers in Holland as well as Belgium and they were slightly hesitant to say the least.
I don't mind to cross the channel or drive over to Germany,France etc. as I am totally fed up with this thing.
All input is greatly appriciated
Cheers,
Michael RRS TDV8 Alaska White,Remap, JE exhaust,DPF Removed
Post #253119 Mon Feb 01 2010 12:47pm
C10KO
Michael,
I would have thought that who ever installed your exhaust system could have removed the DPF filter Whistle
This was the only option available when I was having problems with mine DPF as none of the LR dealers wanted to do it. Revere were very helpful and offered to remove the DPF and install a whole new exhaust system which included rewriting the ECU - this however not only may invalidate your warranty claims but also cost £.
In the end (on third attempt) LR managed to identified the cause of the problems with my DPF (some small sensor inside of the unit was giving false readings). They exchanged the sensor within couple of hours and I have had no problems since Bow down
Hope this helps Thumbs Up
Post #253122 Mon Feb 01 2010 1:02pm
Hangover
Thanks for the info.
The JE exhaust was installed by by delaer before i took delivery of the car.
I gave the nice folks of JE a call but they weren't able to help me out on the DPF issue.
My warranty has surpassed a couple of weeks ago so this is not an issue for me.
I'll give the people of Revere a call to see if they can sort me out.
Edit: Just spoke to Adrian of Revere who told me they weren't able to delete the DPF.
The search goes on...
Post #253124 Mon Feb 01 2010 1:18pm
bellautos
Hangover can you not order the parts in the picture i posted above and get them fitted ?
Pete
Post #253173 Mon Feb 01 2010 8:27pm
Hangover
Hi Pete,
I can order the parts and get them fitted in a jiffy.
Problem is that I would consequently need to change the software.
I've spoken to several dealers about this.
Every dealer served up a different story with the same bottom line that they were not allowed to alter the software. RRS TDV8 Alaska White,Remap, JE exhaust,DPF Removed
Post #253473 Wed Feb 03 2010 3:36pm
C10KO
Hangover, you are asking them to change the nature of the car - quite obviously they will not agree to do it. Though, as your car is out of warranty and this is the modification you are after why don't you take the responsibility on your shoulders? Get the dealer to do it for you by accepting in writing all the potential risk this may cause. I wouldn't see a problem then.
The down side of this is that if anything goes wrong it will be an expensive mistake Whistle
Post #253487 Wed Feb 03 2010 4:18pm
bellautos
Hangover who made the remap on your car ?
pete
Post #253525 Wed Feb 03 2010 8:02pm
Hangover
Thanks for the input C10KO,I've proposed the exact same thing to my dealer.
However he was still reluctant to do so because as a result of the modification my car's emission values would not correspond with the numers stated on the car's certificate of conformity......
@bellautos : job was done by Essing Diesel Tuning from Venray. RRS TDV8 Alaska White,Remap, JE exhaust,DPF Removed
Post #255827 Tue Feb 16 2010 2:04pm
Page 5 of 5 <12345
