![]() | Home > Technical > VARIOUS ERROR MESSAGES!!!! |
skibum Member Since: 07 Sep 2006 Location: North West Posts: 135 ![]() ![]() ![]() |
Had these error messages come up all at same time:-
These problems crop up but if it was the fuel filter I doubt that can explain suspension errors. 2005 Zambezi TDV6 - Gone but not forgotten
Not sure if this bulletin refers to your problems...
bex Member Since: 24 Mar 2008 Location: Abingdon Posts: 179 ![]() |
It is probably poor earth connection on one of the wiring looms |
kljw Member Since: 01 Aug 2006 Location: Edinburgh Posts: 117 ![]() ![]() |
i get the same warnings when my wife drives my tdv8, nothing to do with her driving, she's great, it is to do with the hand controls that i have fitted (legs do not work well after bike crash). the hand controls are linked to both aceel and brake pedal, slight movements can occure in the brake pedal when using the accel, not enought to stop the car, but to trigger a warning that the brake padals are being applied while driving.
David Poyser Member Since: 07 Jul 2008 Location: Derbyshire Posts: 3 ![]() ![]() ![]() |
Having same problem with mine, did fuel filter cure it????????? |
Yep. Its been ok since. Had it done with the 30K service TDV6 HSE 2007 model, Stornoway Grey, Ivory leather,Privacy glass, Premium ICE Pack, side steps, tasmod sills, now towbar and seat covers |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
Bobby delivers the goods once more ![]() ![]() Joint runner up - 2009 Outstanding Contribution Award ![]() WINNER - 2008 �Best Thread� Award � Beautiful Women Of The World ![]() Runner Up - 2008 Comedian Of The Year Award ![]() Runner Up - 2008�s Funniest Incident ![]() 06 RRS TDV6 HSE, Java/Ebony, PTI, Running Boards, Privacy, S/C Grille/Vents, Stormers, Tasmods - GONE - ![]() |
So am I, and round here there is no price advantage over Shell/BP/Texaco to the 2 supermarket fillingstations. I stopped using sainsbury's fillingstation last year and have used Shell/BP/Jet or Texaco since - I'm getting 2-3mpg better too. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it 2018 Melting Silver Mini Countryman PHEV - soon to be replaced 2015MY Corris Grey SDv6 HSE Dynamic, the best car I have ever owned, totally reliable only a cou0le of rattles in 3 years, now no longer in my care Also in my garage is a 1996 TDi300 Defender 90 County HT made into a fake CSW |
jambo Member Since: 31 Aug 2008 Location: Stoke on Trent Posts: 59 ![]() ![]() ![]() |
Just to add my two pence worth - often had problems with the EGR valves becoming faulty on my TDV6 always caused by a build up of sticky carbon (anyone else that had to wait for valves to be on back order i apologise i think most of the UK stock has been used on mine !) always used to use Tesco to fill up as it was cheap, convenient and had a supermarket attached to it which may or may not have done great breakfasts |
I wonder if you always use supermarket diesel, if every so often you should add a few shots of the Diesel equivalent to what used to be called Reddex to a tankful of tractor juice. I have also stopped using supermarket diesel in my Defender which has the 300tdi engine and what a difference there is in that! No more black smoke on acceleration for a start, cannot say there has been a significant improvement in the fuel consumption like the RRS has shown though |
A while ago (can't remember when exactly) Fifth Gear did an experiment on fuel additives and found they made little or no difference. If i recall correctly additives like Reddex work by increasing the cetane value which helps improve the ignition of the fuel - the danger with this is that it's very hard to get the dosing correct in a petrol station environment only accurate way would be to do it on a litre by litre basis.
