Home > Technical > VARIOUS ERROR MESSAGES!!!!
skibum
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Had these error messages come up all at same time:-
TRANSMISSION FAULT LIMITED GEARS AVAILABLE
HDC FAULT SUSPENSION LOWERING
PARKING BRAKE FAULT
This was while travelling at m-way speeds (90ish). The vehicle slows down to 30. I pull over onto hard shoulder, then switch off. Restart and everything ok. But this has happened 6 times in two weeks now.
Car in to stealers today, they tell me its a blocked fuel filter and is common on cars with 28K ish miles. Cos its a fuel filter its non-warranty and will cost c£100
Anyone else have this problem???
(On the plus side just signed up for THIRD FOC LR experience today).
Cheers chaps TDV6 HSE 2007 model, Stornoway Grey, Ivory leather,Privacy glass, Premium ICE Pack, side steps, tasmod sills, now towbar and seat covers
Post #173272 Wed Jun 18 2008 4:16pm
These problems crop up but if it was the fuel filter I doubt that can explain suspension errors. 2005 Zambezi TDV6 - Gone but not forgotten
Post #173291 Wed Jun 18 2008 5:49pm
Bobby
Not sure if this bulletin refers to your problems...
http://www.rrsport.co.uk/gallery/albums/us...ension.pdf
...but I hope it will help. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #173351 Thu Jun 19 2008 12:32am
bex
It is probably poor earth connection on one of the wiring looms
Post #173357 Thu Jun 19 2008 5:55am
kljw
Scotland
similar problems
i get the same warnings when my wife drives my tdv8, nothing to do with her driving, she's great, it is to do with the hand controls that i have fitted (legs do not work well after bike crash). the hand controls are linked to both aceel and brake pedal, slight movements can occure in the brake pedal when using the accel, not enought to stop the car, but to trigger a warning that the brake padals are being applied while driving.
to cure this, i have fitted a spring to help retain the brake pedal in the correct position and so it does not move, this seems to have worked.
be interesting to see what other thoughts people have on this one.
Post #174892 Mon Jun 30 2008 1:42pm
David Poyser
England 2006 Range Rover Sport TDV6 HSE Rimini Red
Having same problem with mine, did fuel filter cure it?????????
Post #176459 Thu Jul 10 2008 1:50pm
skibum
Yep. Its been ok since. Had it done with the 30K service TDV6 HSE 2007 model, Stornoway Grey, Ivory leather,Privacy glass, Premium ICE Pack, side steps, tasmod sills, now towbar and seat covers
Post #176471 Thu Jul 10 2008 3:55pm
Bobby delivers the goods once more Thumbs Up Runner up - 2009 Best Avatar Award Sad
Post #176553 Thu Jul 10 2008 7:57pm
bulldog-winston
United Kingdom 2007 Range Rover Sport TDV6 S Java Black
Had exactly the same problem with my 57 plate TDV6. Cruising on the motorway, suddenly a chime and the following warning sequence :
PARKING BRAKE FAULT
Slowed to a stop on the hard shoulder. Key off, restart and away I went. Must have happened a dozen times after that.
Into my independent garage for a new genuine Land Rover fuel filter and problem solved.
I'm convinced supermarket diesel has a lot to answer for. Shall not be using ever again.
Post #230857 Wed Jul 15 2009 3:59pm
Tim in Scotland
So am I, and round here there is no price advantage over Shell/BP/Texaco to the 2 supermarket fillingstations.
I stopped using sainsbury's fillingstation last year and have used Shell/BP/Jet or Texaco since - I'm getting 2-3mpg better too. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #230877 Wed Jul 15 2009 6:03pm
jambo
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Just to add my two pence worth - often had problems with the EGR valves becoming faulty on my TDV6 always caused by a build up of sticky carbon (anyone else that had to wait for valves to be on back order i apologise i think most of the UK stock has been used on mine !) always used to use Tesco to fill up as it was cheap, convenient and had a supermarket attached to it which may or may not have done great breakfasts Wink - stopped using Tesco and started using Shell 12 months ago and never had an issue with my EGR valves since, like Tim i'm getting more MPG and the car seems to pull more smoothly through all the gears and really flys if i put V power in it. 2005 TDV6 HSE Zermatt Silver Ebony Interior Sunroof, RSE, Side Steps
2002 Honda CBR600F4i plenty fast enough thank you !
Post #230919 Wed Jul 15 2009 11:03pm
Tim in Scotland
I wonder if you always use supermarket diesel, if every so often you should add a few shots of the Diesel equivalent to what used to be called Reddex to a tankful of tractor juice. I have also stopped using supermarket diesel in my Defender which has the 300tdi engine and what a difference there is in that! No more black smoke on acceleration for a start, cannot say there has been a significant improvement in the fuel consumption like the RRS has shown though Big Cry Big Cry 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #230944 Thu Jul 16 2009 9:42am
jambo
A while ago (can't remember when exactly) Fifth Gear did an experiment on fuel additives and found they made little or no difference. If i recall correctly additives like Reddex work by increasing the cetane value which helps improve the ignition of the fuel - the danger with this is that it's very hard to get the dosing correct in a petrol station environment only accurate way would be to do it on a litre by litre basis.
I'm lead to beleive that the fuel supermarkets have is what is left from the base batch of fuel made by the refinery, whereas once the base batch is made it is then dosed with customer specific additives for the likes of Shell, BP, Esso etc and then further additives are added for Shell V Power, BP Ultimate etc.
I actually find due to increased MPG from using V Power that it is cheaper to run my sport on that than it is to run it on supermarket fuel or normal Shell fuel. 2005 TDV6 HSE Zermatt Silver Ebony Interior Sunroof, RSE, Side Steps
Post #231101 Fri Jul 17 2009 10:31pm
