Home > Technical > Chipping Tdv8 |
He said in a previous post that he didn't and the forum lie detector hasn't gone off, so I suppose he's telling the truth!
Fri Mar 30 2007 12:37pm |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 |
S There is a sector of the software called Torque Control which is what I think you are refering to.
Fri Mar 30 2007 12:49pm |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 |
Nope, I'm not in the motor trade in any way. Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Fri Mar 30 2007 12:56pm |
Ah but the D2 box responds to such a tardy valve by requesting the gear shift earlier such that the actual mechanical shift time comes back within spec Its response to sensing overtorque is a bit less impressive as it just drops into limp-home mode (until you cycle the ignition whereupon it decides everything is OK again ). On a damp day my S2-tuned D2 can occasionally be provoked into limp-home by this means but has still managed 177k miles, 117k with the Stage 2 tune on it so it definitely isn't pushing the torque limits of the drivetrain too far. Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Fri Mar 30 2007 1:01pm |
Yes that is correct S
Fri Mar 30 2007 1:17pm |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
Well I guess it all comes down to the old 'factor of safety' built into the design of the mechanical equipment. I guess with LR, their designs will have called for a pretty large margin.
Fri Mar 30 2007 1:30pm |
LRtuning Member Since: 26 Jul 2005 Location: London and Melbourne Posts: 403 |
I doubt there will any major component failures with a throroughly developed engine re-map but I personally have seen problems on BMW's and the gearboxes when the torque increases are too high. Early 3.0D engines with the 5 speed manual gearbox used to destroy 5th gear 'teeth' when the torque increases were over 70Nm....not a huge safety margin
Fri Mar 30 2007 9:16pm |
Yes your dead right LR
Sun Apr 01 2007 6:13pm |
So not much careful development there then nor much understanding of the engineering of the drivetrain components perhaps.... Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Mon Apr 02 2007 9:55am |
I think time will tell how 'safe and reliable' egine remaps actually are....when I was actively involved in the development and quality control at Turbochip in the UK we never had any problems Chips with everything |
Mon Apr 02 2007 10:57am |
Hmm!!!! Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Mon Apr 02 2007 5:40pm |
At the end of the day it's all down to personal choice Chips with everything |
Mon Apr 02 2007 5:46pm |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 |
just my opinion only, however I dont agree - I personally wouldn't supply a product without knowing its been fully tested and that the full failure mechanisms had been determined - FMEA anyone? |
Mon Apr 02 2007 6:03pm |
Kaine,
Mon Apr 02 2007 6:55pm |
