![]() | Home > Technical > Had to happen I suppose |
The doc Member Since: 31 Oct 2006 Posts: 1173 ![]() ![]() |
"I'm afraid we couldn't replicate the reported fault, Mr Josh"... |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
Bad luck Josh, just a thought, have you tried putting the suspension into high and then low then back to normal, it might just be a lazy sensor some of my Previous cars
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
Business as usual at Land Rover then??? ![]() |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
Good idea. Watch the 4x4 display when you do this. Faulty sensors often show up as the wheel bouncing off the red end-stops when you try this. They sometimes do it when you reverse hard, put it in drive and then accelerate forward. I've had two faulty sensors, and both exhibited this behaviour. ![]() |
Philmw did you have them replaced in the end or were they ok after you did this
Replaced under warranty (went within the 1st month, probably a faulty batch). N/S/R went first. Replaced. Week later N/S/F went. Replaced. |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Hasn't done it since....no surprise. Still I'm sure garage can make some money out of the warranty |
Been in. Plugged it in car won't communicate with them or their machine |
Is this where they plug the testbook in and all the car says is:
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
Sorry Josh, can't help with route cause. But I do have a few reservations.
Hm..m food for thought there TB.
bluebarchetta Member Since: 18 Feb 2007 Location: Aylesbury Posts: 10 ![]() ![]() |
My Disco 3 is in at Hartwells (Cumnor nr Oxford) at the moment with a similar problem
