No don't do jet washes. Problem still not come back.TDV6 - gone
TDV8 - gone
Mon Feb 19 2007 5:38pm
Josh
Well there I was leaving work at 4.30am this morning. Suspension light fault again. Tried all the tricks again and its on to stay. Suspension working at all heights.
So drive home and call LR Assist.
Just been turfed out of bed. He pluggs in the lap top and communicates with the car (seems the dealer might be telling porkies after all TB).
No fault on the dynamic side. Fault on the suspension side say there's a fault on the dynamic module
So the tech concludes theres nothing wrong with the car but that its probably a CANBUS problem in that it needs two signals from the suspension module and one is probably too slow in getting to the sensor thus triggering the warning light.
So he's going to tell the dealer that if there is a software update for the suspension that should resolve the problem.
Anyone know if such an update exists TDV6 - gone
TDV8 - gone
Hi Josh, I'm not too clued up on the availability of software upgrades. But I'm sure someone will come along with the information you are looking for.
Glad to hear that you have sorted the communication issue though. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Thu Feb 22 2007 7:37pm
Nutty Nige
Hi Josh
That does not sound right to me
The module fault may be the answer to the comunication fault because if the machine will not communicate it normally means one of the systems is holding the CAN line down that feeds the data stream into the diag tool. If the module was doing this at the time, then that is why it could not communicate and now it is reporting the fault it has logged from earlier in the cycle.
It may be a longer job to define the real problem.
Good Luck
Regards
NigelYou don't stop playing because you get old, You get old because you stop playing.
07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old.
RS Cosworth 4x4 Stage 2 Mint for summer
Audi TT
Astra VXR for the daughter.
Fri Feb 23 2007 12:33pm
Josh
Thanks Nigel.
He did wipe the memory clean before he left. I've driven since with no fault lights. Anyway the Dealer can have it for the 2 days on 12 March. But if it happens again before then, I'll get the mobile Tech out again.TDV6 - gone
TDV8 - gone
