![]() | Home > General > Knocking Sound on RRS Supercharged |
landroverstormer Member Since: 22 Oct 2006 Location: Somewhere close Posts: 325 ![]() ![]() ![]() |
It could be the pully on the charger itself. I understand early cars suffered but this was a screach as opposed to a knock. I assume it is engine speed related as opposed to road speed.
Well you could calm down and switch off the caps lock, then you might get taken seriously! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Please don't post multiple times, and switch your Caps Lock off - capital letters are considered shouting |
homeins Member Since: 13 Jan 2007 Location: NORTH WEST LANCASHIRE Posts: 18 ![]() ![]() |
I am shouting - How can a car cost 64k and have a knocking sound that when asked about I get told its normal for this car are they having a laught |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
dont shout at us ![]() |
Is the noise coming from the engine or from the suspension? BTW it's a SUPERcharged, not a Supper Charge which is something totally different |
The doc Member Since: 31 Oct 2006 Posts: 1173 ![]() ![]() |
Its it from the suspension by any chance? |
Yes I think so it sounds like it does |
I've edited this topic title so it should attract more attention than the original one.
I forgot to mention that that my model is a 1st eddition v8 suppercharged if this makes any diff - I am shattered with the dealers comments that this is normal how can it be - I have had the car back 3x and on the last visit to the doctor the tow truck arrived the driver mentioned that he picks up NO LESS THAN 10 A WEEK!!!!!!!!! nice in it - Shorley thios needs addressing Now why is this not a re-call? |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
Goto topic:
Homeins, can appreciate you frustration over this problem but PLEASE there isn't any need to add the same post to 3-4 sections of the forum all at once. Suggest you stick them in the technical or modifcations sections. The more often you post the same item the less likely anybody will even look at them, let alone read them and it also gives the admin loads of work sorting them out.
Any idea what I can do - I may get thhe aa the carry out a full inspection wat do you all think - I am |
The key is to be patient and work with the dealer to fix the problem. Gather as much information as you can, then go back with printouts etc etc showing that it is a known problem and that it isn't how it should be.
