![]() | Home > Technical > Low Coolant Level |
If the tank is actually full, then it sounds like the dealer has it right. I don't remember that ever being reported on here but that's not to say such a thing wouldn't happen |
eskil Member Since: 25 Dec 2006 Location: Norway Posts: 11 ![]() ![]() ![]() |
ok, it's soon going in 4 a service anyway, should be sorted then. Cheers! |
I had this - the float in the tank is absorbing water and sinks and sets off the low coolant warning. This is a warranty job and has happened to many. 2005 Zambezi TDV6 - Gone but not forgotten
I have it for the past 3 weeks already.
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
There is actually a TSB issued for this (see the NA version below, the one in Europe may or may not be different.) Problem is, for a while dealers in the US were replacing faulty expansion tanks with more faulty tanks!
Thanks umbertob.
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
I have this right now - been doing it infrequently for a while and mentioned it last week during service, apparently the bottle material cracks somewhere allowing the sensor to become saturated - fix is new bottle. They had to order one and they are on backorder.... under warranty... |
Yep, had this after the dealer fitted the FBH which required draining the coolant down. I thought they hadn't fully refilled the reservoir and complained that they had had the car for 3 days and should have run it enough to find out if there were air locks. Turned out to be the sensor was faulty too. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Yep, mine has had that and is in at the moment getting it sorted. Also having some other minor work done.......namely the entire drivline being replaced |
baxtermiller Member Since: 15 Jan 2007 Location: Corona, Ca Posts: 2 ![]() ![]() ![]() |
I thought it was just me. Thanks for the responses. I will go stand in line for a back ordered part once again. :lol: |
Welcome Baxter! Don't worry, there are very few problems that are "one offs", so if you do get a prob, just check out a few of the forums and you will more than likely find a solution! RRS TDV6 Bluetooth, VR, Roof ![]() |
Parts appear to be off backorder in UK now - booked in for Thursday... Also having OSR door seal replaced on pillar - adhesive drying out and peeled away... |
muz1000 Member Since: 10 May 2009 Location: Sutton Coldfield Posts: 33 ![]() ![]() ![]() |
I just had mine done �155.00 plus VAT from my local Stealer. |
