Home > Technical > Low Coolant Level
eskil
Norway 2005 Range Rover Sport Supercharged Java Black
Low Coolant Level
My 05 S/C show constant low coolant level. The level in the expansion tank is correct, and the LR guys reackon its a faulty sensor in the tank which needs a whole tank replacement. Anyone had anything similar?
Post #74169 Wed Jan 10 2007 8:19pm
If the tank is actually full, then it sounds like the dealer has it right. I don't remember that ever being reported on here but that's not to say such a thing wouldn't happen Very Happy
Post #74174 Wed Jan 10 2007 8:33pm
eskil
ok, it's soon going in 4 a service anyway, should be sorted then. Cheers!
Post #74178 Wed Jan 10 2007 8:53pm
I had this - the float in the tank is absorbing water and sinks and sets off the low coolant warning. This is a warranty job and has happened to many. 2005 Zambezi TDV6 - Gone but not forgotten
Post #74181 Wed Jan 10 2007 9:15pm
Bobby
I have it for the past 3 weeks already.
Still waiting for the part... Mad Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #74197 Wed Jan 10 2007 10:59pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
There is actually a TSB issued for this (see the NA version below, the one in Europe may or may not be different.) Problem is, for a while dealers in the US were replacing faulty expansion tanks with more faulty tanks! Crying or Very sad There must have been a big batch of them around. Make sure your dealer is aware of the TSB, as you can see there is a specific manufacture date or code on the "good" tanks they need to check before installing. I am sure they are aware of that by now, but this is Land Rover and you never know...
Quote:
TSB# LS303-006
SECTION: 303-03
"Low Coolant Level" Message or Warning Lamp Illuminated
AFFECTED VEHICLE RANGE:
Range Rover Sport (LS) VIN: 6A900129 to 6A929342
CONDITION SUMMARY:
"LOW COOLANT LEVEL" MESSAGE OR WARNING LAMP ILLUMINATED
Situation: A customer may report that the "Low Coolant" amber warning lamp is illuminated or a "Low Coolant Level" message is displayed in the Message Center when the engine coolant expansion tank volume is within recommended levels.
The coolant level float in the expansion tank can absorb coolant causing the float to sink. The warning lamp and message will display when the float sinks below the low level sensor trigger point.
Action: Should a customer express a concern related to the above condition, within the specified VIN range, refer to the Repair Procedure detailed in this bulletin.
PARTS:
NOTE: The current expansion tank part PCF500015 may be used only if the sticker on the side of the part has a date of 31-10-05 (DD-MM-YY) or later. A newer part PCF500090 may be used when available.
PCF500015..............Coolant expansion tank (dated 31-10-05 or later) Qty 1
PCF500090..............Coolant expansion tank Qty 1
Post #74200 Thu Jan 11 2007 12:07am
Bobby
Thanks umbertob.
I will certainly forward a copy of this TSB to the guys at Land Rover... . Malaysia Boleh!
Post #74201 Thu Jan 11 2007 12:20am
MAW
Re: Low Coolant Level
I have this right now - been doing it infrequently for a while and mentioned it last week during service, apparently the bottle material cracks somewhere allowing the sensor to become saturated - fix is new bottle. They had to order one and they are on backorder.... under warranty...
Post #74222 Thu Jan 11 2007 8:44am
Embarassed Seems more widespread than I thought... what do I know, I drive a BMW! Laughing
Post #74237 Thu Jan 11 2007 9:37am
Tim in Scotland
Yep, had this after the dealer fitted the FBH which required draining the coolant down. I thought they hadn't fully refilled the reservoir and complained that they had had the car for 3 days and should have run it enough to find out if there were air locks. Turned out to be the sensor was faulty too. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #74280 Thu Jan 11 2007 11:21am
Lateral5
Australia
Yep, mine has had that and is in at the moment getting it sorted. Also having some other minor work done.......namely the entire drivline being replaced Confused RRS TDV6 Bluetooth, VR, Roof
Post #74808 Sat Jan 13 2007 2:27am
baxtermiller
United States 2006 Range Rover Sport 4.4 V8 HSE Zermatt Silver
coolant level
I thought it was just me. Thanks for the responses. I will go stand in line for a back ordered part once again. :lol:
Post #75161 Mon Jan 15 2007 1:37am
Lateral5
Australia
Re: coolant level
baxtermiller wrote:
I thought it was just me. Thanks for the responses. I will go stand in line for a back ordered part once again. Laughing
Welcome Baxter!
Don't worry, there are very few problems that are "one offs", so if you do get a prob, just check out a few of the forums and you will more than likely find a solution! RRS TDV6 Bluetooth, VR, Roof
Post #75163 Mon Jan 15 2007 2:00am
MAW
Parts appear to be off backorder in UK now - booked in for Thursday... Also having OSR door seal replaced on pillar - adhesive drying out and peeled away...
Post #75559 Tue Jan 16 2007 8:55am
muz1000
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Expansion Tank replacement Cost
I just had mine done £155.00 plus VAT from my local Stealer.
Post #228684 Sun Jun 21 2009 12:27pm
